Results 1 to 10 of 15
Thread: My gullwings (anyone can make)
    Expert Ben89's Avatar
    Feb 2012
    Thought I'd share my gullwings for some inspiration
    Nice and simple, just 4mm ally sheet (for inside the GQ solid cargo rubber) and 3mm for the hinge door and some 10mm offset hinges IMG_20200830_180136.jpgIMG20200830165026.jpg
    Don't take life too seriously. No one gets out alive.
  2. The Following 6 Users Say Thank You to Ben89 For This Useful Post:
    0-TJ-0 (1st September 2020), MB (30th August 2020), mudnut (31st August 2020), MudRunnerTD (30th August 2020), mudski (30th August 2020), tryan277 (30th August 2020)
    I see! The 4mm replaces the glass and then you hinge off that. Nice! Something I want on my GU...
    Feb 2012
    Yep, simple and watertight
  5. The Following 3 Users Say Thank You to Ben89 For This Useful Post:
    BrazilianY60 (27th November 2024), MB (30th August 2020), mudski (1st September 2020)
    Advanced tryan277's Avatar
    May 2016
    Melbourne, Southern Burbs
    Love you work. Could you take some more photos please. Like Mudski want to do this.
    Cheers Trevor
  7. The Following User Says Thank You to tryan277 For This Useful Post:
  8. #5
    Feb 2012
  9. The Following 8 Users Say Thank You to Ben89 For This Useful Post:
    0-TJ-0 (1st September 2020), MB (31st August 2020), mudnut (31st August 2020), mudski (1st September 2020), PeeBee (31st August 2020), threedogs (1st September 2020), Touses (1st September 2020), tryan277 (31st August 2020)
  10. #6
    Great mod 10/10 nice neat work
    gotta luv that eh
  11. #7
    Jun 2020
    WA
    This is such a high quality looking job. All in, how much did the two wings cost you?
    I’d like to do this to my patrol in the near future. How did you secure the 4mm glass replacement sheet?
    Did you cut and spray the sheet yourself?
    Any info is much appreciated
  12. #8
    Feb 2012
    Ally sheet was free which I cut into shape and powder coating also free through work, 4mm glass replacement peice was secured with the same rubber you use for the glass.
    Hinges were about $60 all up I recon
    Was thinking about getting some Lazer cut and selling them
  13. The Following 2 Users Say Thank You to Ben89 For This Useful Post:
    MB (3rd September 2020), Plasnart (3rd September 2020)
  14. #9
    Quote Originally Posted by Ben89 View Post
    Do it before someone else runs with it.
  15. The Following User Says Thank You to Plasnart For This Useful Post:
    rusty_nail (3rd September 2020)
  16. #10
    May 2016
    My take on the inspiration of Ben89
    Removed the passengers side sliding window - no rust great
    mounted the new rubber seal and measured many times and use glass panels for radius corners and cut a 4mm sheet and test fitted
    On to the drivers side and repeated the process to include the "door" also no rust
    A couple of things I did differently to Ben89, the locks I used can be closed without a key but still lockable but not waterproof and I cut the "frame" so the pinch weld seal passed between the lower mounting screw and upper mounting screws of the hinge. I did not get this quite right as the upper mount screws still just catch the pinch weld seal so at the moment I have eased the pinch weld down a small amount as can be seen in the last picture. In the process of doing the passengers side and have allowed a bit more clearance. The offset hinges I used did not have enough offset so had to block them out by 5mm. Have not had the vehicle out on the road yet to see if there is any wind noise.
    Cheers Trevor
  17. The Following 6 Users Say Thank You to tryan277 For This Useful Post:
    Bojordan (7th November 2020), Cremulator (7th November 2020), MB (6th November 2020), MudRunnerTD (6th November 2020), Rossco (6th November 2020), Stropp (17th May 2021)
