Page 47 of 106 FirstFirst ... 4546474849 ... LastLast
Results 461 to 470 of 1053
  1. #461
    Whoops, my bad sorry mate, you meant the man, not the machine :-)
  2. #462
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    With the recent discussion on welders, I couldn't resist posting this here. I know it's not the right place, but . . . .:IMG_3131.JPG
  3. The Following 9 Users Say Thank You to Brissieboy For This Useful Post:
    jay see (18th August 2020), MB (18th August 2020), Mickhead (20th August 2020), mudnut (18th August 2020), mudski (21st August 2020), PeeBee (18th August 2020), Plasnart (18th August 2020), Touses (18th August 2020), TPC (20th August 2020)
  4. #463
    Expert Mickhead's Avatar
    Oct 2019
    Quote Originally Posted by Brissieboy View Post
    Unless thats a really bad pic I would be offering an extra 15 bucks per hour to get rid of the undercut and the lack of penetration in weld number 2
  5. #464
    Oct 2019
    [QUOTE=jay see;807454]Well after some googling and taking in the information from you guys and some of the guys at work. I'm pretty sure that I'm going to go with a 135 amp machine.
    Reason for this is the 2 people that have these are happy with them mudski (cigweld) and a guy from work(Michigan). Yes a bigger machine probably would be better, but I need to look at the cost as well, anyway if I need to do big long welds and I can't do them at home, I can always get it done at work.
    I went down the cheaper path too first time with the rossi welder. A 130 amp Mig only welder will do anything that needs welding on the pooey. But if it costs 300 bucks to buy, and you have the option of spending another 200 to 300 on a Bossweld / unimig / boc ( cigweld ) unit think hard because if you need the extra power or the ability to tig you will be unhappy. Been there, done that. And a lot of the cheapys have a non removable torch. Avoid this if you can!
  6. The Following User Says Thank You to Mickhead For This Useful Post:
    jay see (20th August 2020)
  7. #465
    [QUOTE=Mickhead;807742]
    Yeah, too late.
    I probably should've posted it here, but check out the happy thread.
    I mentioned earlier somewhere that if I need to do bigger longer welds and this machine can't handle it, I can get it done at work by a professional welder and I don't see any need for a tig, well but for me anyway.
  8. #466
    Oct 2019
    69FAB15D-1D9C-4026-A315-FDFC67C9B69B.jpeg[QUOTE=jay see;807743]
    Quote Originally Posted by Mickhead View Post
    Yeah, too late.
    Looks like it does the job, bit messy with the gasless, Mate, you have way more patience than me .. nice work my gasless trial run lasted 30 seconds!
    Bet you buy another welder within a year...
    Love my tig
  9. The Following User Says Thank You to Mickhead For This Useful Post:
    jay see (21st August 2020)
  10. #467
    cannot believe what i have seen this arvo. milwaukee have just taken cordless tools to the next level, like seriously...
    https://www.totaltools.com.au/152457...30dbf2598207a1
  11. The Following User Says Thank You to rusty_nail For This Useful Post:
    10G (24th August 2020)
  12. #468
    The whole range of mx fuel tools are absolutely insane.
  13. The Following User Says Thank You to Winnie For This Useful Post:
    rusty_nail (23rd August 2020)
  14. #469
    The latest additions.
    Battery was a $85 market place buy.
  15. The Following User Says Thank You to jay see For This Useful Post:
    10G (18th September 2020)
  16. #470
    198 Post(s)
    What are your thoughts on the Rossi brand - this one in particular? garage use only. I have the 130amp mig at the moment , again a Rossi, but even on gas and full power it does not lay a good bead - struggles to get the metal down and its a generally horrible looking result - i am resigned to park it under the bench.
    https://www.ebay.com.au/itm/ROSSI-22...53.m1438.l2649
    Update - I finally got to the bottom of my Rossi 130amp MIG and its weld issues. After many emails back and forth the supplier finally admitted the welder was not as advertised however its my responsibility to see thru the information and do my own research - Yep, what a process. the welder is specifically sold for metal, mild steel, stainless, gas or gasless. Problem is the description is basically a cut and paste from other welders as the distributor is simply a wholesaler, which explains why it took so long to get to the bottom of the issue.
    To weld MS and SS with a MIG you need a DC welder. This unit is AC. AC is good only for Aluminum, gas or gasless. The distributor has wiped his hands of the issue, its mine now. The welder was purchased off EBAY from EDISONS. Don't trust this seller. Won't take it back, won't refund the cost and won't even entertain a return and upgrade to a welder that actually will do what the advert says. Very pissed off, but there is nowhere to go to appeal.
    At least it confirms it wasn't operator error - this time!!
