Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: ZD30 intercooler
    Advanced Oddie1969's Avatar
    Jun 2013
    Perth
    ZD30 intercooler
    Hi all. Just wondering if someone could tell me how hard it is to change the intercooler on a 2006 3.0lt. I’ve misplaced my Haynes manual so I’m just wondering if it’s just remove and replace of is there more involved than that ?
    Thanks in advance
    Graham
    Should take less than a stubbie to remove and refit. Two hose clamps, unclip a sensor and four bolts....
  3. The Following 2 Users Say Thank You to mudski For This Useful Post:
    0-TJ-0 (21st July 2020), Oddie1969 (21st July 2020)
    Jun 2013
    Perth
    Right, that sounds like something even I might be able to manage, thanks 👍
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    I don't know a screwdriver from a spanner and I got it done on my own.
    I did leave a blanking bolt out but got that sorted quickly
  6. The Following User Says Thank You to Mc4by For This Useful Post:
    Jun 2013
    Perth
    Quote Originally Posted by Mc4by View Post
    Ha ha. 🤣 Mine is leaking a lot of oil so I wasn’t sure if there were oil lines that needed to be considered, after a bit more reading it looks like that may be coming though with the air.
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    When you say "fitting a new one" are you talking original or aftermarket? Some of the aftermarket ones (like the one I purchased years ago) are a pain to fit. Most Patrol owners these days get the original IC modified by getting the core removed and a more efficient core TIG welded in its place. This gives you better cooling of air plus it wont leak AND it is guaranteed to fit.
    May 2016
    lower west victoria
    30 Post(s)
    Quote Originally Posted by Oddie1969 View Post
    Yep, do you have a catch can fitted?
    I live in the "don't know a screwdriver from a spanner" drawer as well plus I specialise in forgetting things, but the oil will be coming from your PCV blowing back into your air inlet. The catch can goes a fair way towards removing that oil. Please someone correct me if I'm wrong.
    There's not meant to be oil in the IC, just wind.
  10. #8
    easy enough to change once the engine cover is removed.
    Not sure on prices but a change over IC fully tigged will
    be approx 33% bigger
  11. #9
    Jun 2013
    Perth
    Aftermarket direct swap. Welded instead of crimped but all the same dimensions. All done, went in like a dream.
  12. #10
    Jun 2013
    Perth
    Ha ha, we sound like twins !
    No I don’t have a catch can, I was reading about those, are they worth it ? Do I need to be cleaning anything else so the intercooler doesn’t get clogged up again ?
