Results 11 to 20 of 25
Thread: Electrical interference with HF radio
    WA Wheatbelt
    23 Post(s)
    My HF Codan NGT AR interferes with my UHF 80 channel CB. I can only have one on at a time when the vehicle's moving. Haven't tried both on when stationary yet. I get intermittent to full time static in my UHF from the HF.
    @the evil twin might be able to help.
  2. The Following User Says Thank You to DX grunt For This Useful Post:
    PeeBee (10th July 2020)
  3. #12
    I haven't posted as there is not much that others haven't already suggested... IMHO it seems suspiciously like a couple of issues IE I think there was /is an earth loop which improved when everything was disturbed and possibly something else is leaking HF interference.
    HF is a black art at the best of times so sacrificing a virgin chicken at midnight on the solunar equinox using a crystal blade with a unicorn bone handle shaped by dwarves can often help...
    If you can't do that the next best thing I found to help with dodgy comms kit during my time in the military is swear a lot while kicking the shit out of it.
    Rarely gets it too work but you def feel better for it.
  4. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    mudnut (11th July 2020), Plasnart (10th July 2020)
  5. #13
    Thanks gents, I am going to launch into the earthing checks next monday after the wife goes back to work and I have an uninterrupted period of time to work thru it. Strange its only in this particular band around 8meg, but it affects 4 channels from 7.2 - 8.5meg - damn annoying.
  6. #14
    .......... TPC's Avatar
    63 Post(s)
    Hi Phil, if you want to pm your phone number I could give you a call to chat about the problem.
    Noise on HF can be a bugger of a thing to track down and is worse with older vehicles as earthing between different parts of the car can be resistive.
    If you were close I would try and track it down with a spectrum analyser but you Covid 19 infected Mexicans can't mix with the rest of us.
  7. #15
    84 Post(s)
    But you Covid 19 infected Mexicans can't mix with the rest of us.
    When you're near Mt Gambier, Phil could come here for a visit. We could drive past Nelson, and push his driverless Patrol across the border. You could fix it and send it back
  8. #16
    I like that idea, but will take a few to get this barge rolling! I will speak with Tony tomorrow sometime and see if he has any specific ideas or different starting points. This forum is great for stuff like this I reckon.
  9. #17
    63 Post(s)
    Haha, problem is I was in the mount this week
  10. #18
    OK, I finally got to this issue and think its resolved. I cleaned off the earth points across the whole vehicle, and also added a second flat braid earth strap between the 9350 auto tuner and the chassis, all using a conductive paste at the joints. the background noise on receive went down on most channels to 1/5. on anything between 6.8 and 10.1mhz, the noise level dropped to 3/5 from 5/5. I am able to hear traffic even in Metro Melb with Covid-19 virus in the air, so am happy i think. The next bush trip will be the telling point. What is interesting though, if I then select a channel and push the tune button, the background noise rises to 4/5 on those pesky freq's above, and the 3/5 for the other quiet frequencies. I might end up taking the set across to lara Electronics and have Peter James run his expertise over it just to be sure.
  11. #19
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Do you know anyone else that has the same set up? Swapping items one at a time to eliminate each is the way to go. Otherwise you just keep chasing your tail.
  12. #20
    Unfortunately no, I am working thru a process of elimination, however even with the radio powered off a totally independent battery, not connected to the car, the base noise level is high, so I will see what its like next time I am out in the bush, away from all the passive metro noise. If its still noisy then the radio may need checking. From what I can see, the installation is fine.
