Results 1 to 10 of 13
Thread: Front lockers in a Gq Pro and Cons ?
Threaded View
  1. #3
    176 Post(s)
    In that scenario, autolockers wouldn't be the way to go. The ability to switch the locker on and off would give you a tight steering circle when required.
    I am saving up for an E-locker.
    If you haven't already driven with one, I think you may be surprised how much steering you get with an E-locker. A couple of times I've been on hills requiring 'commitment' , with rock steps, & twists & turns. Switched on the e-locker at the bottom & just drove up & around the twists & turns. Not the sort of terrain where stopping to switch off the e-locker was a consideration, especially with the Tvan in tow!
    Something I did learn since we've been away was in very tight stuff where maximum tightness of steering was required, was to change to 2wd to get around the obstacle in question. I suppose most people know that, but I'd never been told , or read, to do that. The leaf sprung GU utes do have a significantly larger turning circle than their coil sprung siblings.
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    PeeBee (21st June 2020)
