Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Shortie shortening :)
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    Here's the old girl resting, as it has for two years. All we've done is get the engine out. Sold that and set about undoing the body mounts. Undid the looms and ripped off the rotten fuel pipes. Welsh winters salty roads
    Plan was to lift the body up and pull the chassis out from under it. So we made a frame to support the body onto. A few metres of 50mm box and a welding boy produced this in about an hour or so
    I've made it adjustable so it can be lowered down etc if needed.
    One of the guys in the neighboring units has a telly handler thing, so bribed him with 20 minutes of sheep action for a quick body lift
    While the body was aloft we put the cradle underneath and then plonked the body back down onto it.
    Then it was simply a case of pulling the chassis into the workshop via the pressure washer. For this I did a steering mod
    Cleaned many old adventures off the poor thing
    On the lift and first look properly suggests it's not too shabby amazingly. This is a retaliative term here in wild west wales
    The tail ends by the tank are rotten but not needed any more so off they go
    Shortening the front next , see you later
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
  2. The Following 8 Users Say Thank You to makeitfit For This Useful Post:
    10G (15th July 2020), Cuppa (21st June 2020), MB (1st August 2020), mudnut (18th June 2020), MudRunnerTD (19th July 2020), Rossco (18th June 2020), rusty_nail (18th June 2020), Touses (14th July 2020)
    I am going to enjoy this journey. Keep going, great stuff.
    Legendary happygu's Avatar
    Looks like a bit of fine work to pass the time ..... a bit of rust kill and paint on the chassis will go a long way to making it look a million dollars again....
    Aug 2011
    Here be some more goings on.
    Chassis chop 15cm off the front end. Aiming for a more aggressive attack angle .
    Then relocated body mounts
    Years ago in preperation for this very job, I bought some swivel recovery points. Amazed myself by finding them in my heap of things
    So I made up a template and cut the 6mm plate to suit the inner chassis section.
    Here sprayed in weld through primer.
    Cleaned up the inside a bit & close enough for welding .
    Boyo has done his magic again closing up with typical toothpaste weld
    Close up weld porn anyone
    Next up I'll tell you all about making two barn doors into a drop down taigate
  6. The Following 5 Users Say Thank You to makeitfit For This Useful Post:
    10G (15th July 2020), Cremulator (19th June 2020), mudnut (20th June 2020), MudRunnerTD (19th July 2020), Rossco (19th June 2020)
    Yer those welds are neat mate! I reckon@MudRunnerTD would have done a far neater job. I'm kidding but those welds are bloody neat!
  8. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
    MudRunnerTD (19th July 2020), Rossco (20th June 2020)
  9. #6
    Aug 2011
    I wish they were mine but they are in fact my son's work. I taught him everything I knew in about 5 minutes .... my eyes don't help . The boy always asks if I had the gas on when he looks at my welds lol
    I'll pass on your kind words though
  10. The Following 4 Users Say Thank You to makeitfit For This Useful Post:
    10G (15th July 2020), MudRunnerTD (19th July 2020), Rossco (21st June 2020), rusty_nail (21st June 2020)
  11. #7
    Aug 2011
    Here in deepest darkest west Wales we still have plenty of feckin' rain .....
    So in a kind of out of sequence job we got on with making the barn doors into a tailgate, as you do
    Incase I hadn't made it clear, I'm cutting up the old girl into a pickup. Extending the wheel base , shortening front and back overhangs.
    Part of the job was cutting up the barn doors to make them into a drop down tailgate.
    Sooo, I set about the door strip down .
    Then repeat on little door . Pushed together for a trial looksee at gaps etc
    Happy with that so welding it is then
    Many hours disappeared on this job, but as it was pissing down big style we didn't mind so much.
    Eventually a little bit of origami metalwork and another small hole filled
    More spray weld through primer and jigsaw piece done
    and on and on filling hinge holes etc till we eventually got this far
    Got a few little screw holes to fill then body filler then prime etc etc
    Loads more to do just on this bit, like find some hinges ??
    Hardly any patrols round here , never mind pick ups, so finding hinges could be fun
  12. The Following 4 Users Say Thank You to makeitfit For This Useful Post:
    10G (15th July 2020), mudnut (21st June 2020), MudRunnerTD (19th July 2020), Rossco (21st June 2020)
  13. #8
    178 Post(s)
    Goodonya boyo, I'm enjoying this.
    Btw -the proper name for a 'pickup' is a 'ute'.
  14. #9
    Aug 2011
    You say UTE, I say pickup.
    You say guard, I say bumper.
    What ever it's called we both call it fun
    Now then, the rain has stopped and so I got my ladder out to chop the top, of my pickute
    I spent many years trying to decide where I would go with the Trol and at last I'm marking out
    As they say, the first cut is the deepest , so time to chase the white line !!!
    I welded in a brace just incase things moved .
    9" grinder time, up a ladder , in the mud Nothing to see here
    Then boom , D posts gone .
    I'll be using this bit later, best put it safe
    Then back up me ladder and repeat
    Quite like it as it is but there's no room for the seat like this , so now I need to add the rear end again.
    First go at fitting it.
    Then many fiddly cuts later the gutter is pretty close
    More wallop stick action and getting closer again
    I've got to the point of reasonable roof line but the gutters are slightly narrower from the rear end.
    Tomorrow's problem solution session will be fixing this width issue !
    Answers on a postcard please
  15. The Following 6 Users Say Thank You to makeitfit For This Useful Post:
    10G (15th July 2020), Cremulator (22nd June 2020), Cuppa (12th July 2020), MudRunnerTD (19th July 2020), rusty_nail (22nd June 2020), Touses (14th July 2020)
  16. #10
    Sep 2018
    queensland
    this is cool, wish i had your skill.
    got me hooked cant wait to see the next update
