Results 1 to 10 of 39
Thread: Shortie shortening :)
Threaded View
  1. #4
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    Here be some more goings on.
    Chassis chop 15cm off the front end. Aiming for a more aggressive attack angle .
    Then relocated body mounts
    Years ago in preperation for this very job, I bought some swivel recovery points. Amazed myself by finding them in my heap of things
    So I made up a template and cut the 6mm plate to suit the inner chassis section.
    Here sprayed in weld through primer.
    Cleaned up the inside a bit & close enough for welding .
    Boyo has done his magic again closing up with typical toothpaste weld
    Close up weld porn anyone
    Next up I'll tell you all about making two barn doors into a drop down taigate
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
  2. The Following 5 Users Say Thank You to makeitfit For This Useful Post:
    10G (15th July 2020), Cremulator (19th June 2020), mudnut (20th June 2020), MudRunnerTD (19th July 2020), Rossco (19th June 2020)
