Results 1 to 10 of 18
Thread: Nissan / Airtec Snorkel head
    May 2016
    lower west victoria
    30 Post(s)
    Does anyone know if there is a different head that can fitted onto the Nissan / Airtec snorkels. They look terrible and don't seem large enough.
    Alternatively, does anyone know if you can replace the Nissan / Airtec snorkel with a Safari? Do the holes match up???
    Thanks.
    What size is the snorkel where the ram head sits on? I get the Yota with their 79's come into my work a bit wanting to change the Toyota bowl setup to a Donaldson ram head. So we just need the pipe size to work out what you need.
    May 2016
    lower west victoria
    30 Post(s)
    That sounds great Mark. The problem with the Airtec is that body of the snorkel follows the A pillar and the bend is in the head. So if you try to put a different head on it, the inlet ends up staring up at the sky.
    I measure the diameter of the part that the head slips over as being 87mm.
    Ok so we'll say its 89mm, 3 1/2 inch. Theres not a whole lot you can do here. The only option I see is get a 45 degree adaptor which is 89mm ID to slip over the snorkel, then its 89mm OD then you can fit a standard Donaldson snorkel. In the hope that 45 degrees is what you require to see the snorkel head straight.
  5. #5
    Patrol Guru TimE's Avatar
    Canberra
    Mate had an adapter made up (for his Tojo) at the local exhaust shop a few years ago. Might be worth a try?
  6. The Following User Says Thank You to TimE For This Useful Post:
    Rossco (2nd June 2020)
    May 2016
    lower west victoria
    30 Post(s)
    I've stumbled onto a bloke who prints up snorkel adapters on a 3D printer. I'm working with him to see what we can come up with.
  8. The Following 2 Users Say Thank You to 10G For This Useful Post:
    mudski (2nd June 2020), Rossco (2nd June 2020)
    You want to hope it will be strong enough.
  10. #8
    178 Post(s)
    On the same note
    Has anyone successfully managed to fit a cyclonic pre cleaner onto one of these snorkels. If so how & what size (min/max airflow) cleaner? (for TD42i)
  11. #9
    May 2016
    lower west victoria
    30 Post(s)
    He prints the adaptors out of ABS and does something with acetone to make them stronger.
  12. #10
    May 2016
    lower west victoria
    30 Post(s)
    On the same note
    G'day Cuppa. That's what this blokes adaptors are for, so you can fit a pre-cleaner. As an example:
    https://www.ebay.com.au/itm/14361418...torefresh=true
