Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Zd30 no power
    May 2020
    Zd30 no power
    Hey guys just bought my first Nissan patrol hoping to do some off roading and camping with it, but I am having major power problems with it seems like it’s not getting enough fuel into the engine and loosing power, have already changed diesel filter and cleaned the mass air sensor no improvement 😩 all tips appreciated, cheers
    Sep 2018
    queensland
    Bit more info, is it a common rail zd30 or Di?
  3. The Following User Says Thank You to Fireblade For This Useful Post:
    Avo (29th May 2020)
    May 2020
    It’s the ST model, direct injection, it’s loosing power going up hills
    84 Post(s)
    Disconnect the battery for half an hour to reset the ECU. If it still carries on, pop into SCA and get a scan done to see if there is any codes.
    May 2020
    Ya I’ve tried disconnecting the battery already and still same issue after reconnecting, my latest test was testing the voltage out of each port of the MAF so there is a red wire, white wire, black wire, white wire in that order, all wires read correct voltage except for the red one, was getting a reading of 0 volts on that one and it is suppose to give a reading between 1.6 to 2 volts. So maybe this is the issue, does anybody know where this red wire goes to?
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    84 Post(s)
    Download the workshop manual and check out the wiring diagram.
    http://www.nissanpatrol.com.au/forum...-with-CRD-info
    Sep 2018
    queensland
    I don’t know a lot about Di ones but fuel filters sucking air have been common among the ones I’ve seen. After people replace them they loose the o’ring on top. Not saying that’s to ur issue though also seems the push primer suck air but my experience with Di zd30 is limited to about half a dozen.
  10. #9
    May 2020
    Thanks for all reply’s guys, Thanks for the link mudnut but won’t let me into it, fortunately I already have found a manual so all good, I’ve traced the line all the way back to the ecu and I’ve tested the line (no break in the line) possibly an ecu issue, but there seems to be a relay somewhere in that line so I’m going to try track that down and hopefully that’s my problem rather than the ecu.
  11. #10
    476 Post(s)
    Quote Originally Posted by Mikefinn View Post
    In what way? Like your dragging a heavy trailer? Or is the power just instantly shutting off?
    Any mods done the the motor? Any recent repairs that you know of? Auto? Manual? If auto, is it in overdrive when this happens, If in manual, what gear are you in? What RPM is it happening at? Do you have a boost gauge? EGT gauge? Hard to help with the little info given.
