Page 36 of 98 FirstFirst ... 3435363738 ... LastLast
Results 351 to 360 of 972
  1. #351
    Yep buttons on the bar are a must! I left them out and really regret it, running out the winch rope solo is a mission now. Need to find some motivation to add them in.
    A light above the winch that illuminates when you activate the in cab isolation switch is also a bloody good idea too, I didn't do that either damn it.
    What he said. I find myself in the same predicament.
  2. #352
    Guys what are the advantages of the buttons as against the control cable and handset? I ask as I have a 8m cable for both the front and rear winches and don't find it a problem getting cable off or on and can stay well out of the line of fire as well. Is this more for re-spooling after a recovery?
    I also added a led strip light over the front winch drum and makes a big difference for sure, need to work one out for the rear - somehow
  3. #353
    In my case, my controller sh!t itself and I couldn't find a replacement (t max) I also needed to replace the solenoid So I decided to run in cab controls.
  4. The Following User Says Thank You to jay see For This Useful Post:
    PeeBee (28th May 2020)
  5. #354
    Yeah buttons are for respooling with no load and also highmounts without a snazzy air freespool upgrade need to be powered out with the motor as the factory freespool is damn near useless as your spinning all the gears by hand and is very hard yacka. Convenience of buttons vs plug in controller is you don't have to fish it out, plug it in, feed throug window etc, but other than that serves same propose. Also as you ending up building the whole system from scratch it's eaisier and cheaper to source switches and all the gear to sit up this way if that makes sense. .
  6. The Following User Says Thank You to Rossco For This Useful Post:
  7. #355
    @Rossco ; I think I have it worked out without the external switches.
    Can you use your external switches with the isolator switch off?
  8. #356
    22 Post(s)
    All the lights will be on as soon as you switch on accessory power.
    Should the lower lights be switched with the isolator or come on with headlights? Or do you just want them on
    96 GQ coil/Cab
    08 G6eT
  9. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    mudski (28th May 2020)
  10. #357
    Ah yeah I see. If I link 4 to 1 and 6 to 3 they should come on when pressed... Thanks.
  11. #358
    Should be right now?
  12. #359
    6 from the isolator switch should go to a wire that picks up power when headlights on. The buttons up front on mine don't work unless isolator is on, so just pick up power from 3 on isolator switch and also use this for your led strip light if your going to use it.
  13. The Following User Says Thank You to Rossco For This Useful Post:
    mudski (29th May 2020)
  14. #360
    Advanced tryan277's Avatar
    May 2016
    Melbourne, Southern Burbs
    My 2 cents worth
    Separate the location of the winch isolator switch and the operational switch (in/out)
    Isolator on dash somewhere where it cannot be easily knocked (and winch powered up without realizing) and in/out switch on console. If things are hairy don't want the switches next to each other, and in haste press the wrong one!
    Consider a wireless remote. If caught out on your own can spool out while dragging winch line to point of attachment and winch back in to take up slack ensuring straps, protectors etc position themselves as intended, before doing the actual recovery.
    Cheers Trevor
  15. The Following 2 Users Say Thank You to tryan277 For This Useful Post:
    jay see (29th May 2020), mudski (29th May 2020)
