Results 1 to 2 of 2
Thread: Fuel Bleeding Problems - GQ Patrol
    Apr 2020
    Hi team,
    I have bought a 97 RX Nissan Patrol - 2.8 Turbo Diesel - not running -as a project . I have bleed the fuel system right up to the Injector pump. However I cant get fuel to show at the injectors , I have cracked all the injector pipes and cranked over -No Fuel , is there a bleed screw on the injector pump. I also cracked the injector pipes at the pump end and cranked over but now fuel coming out. So it appears fuel line going to the pump is fine however nothing coming out of the injector pump to the injectors...any help appreciated.
    Could this be something to do with Fuel stop solenoid ????
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Not sure on the 2.8.. But the 4.2 won't show fuel at the injectors if the fuel stop solenoid doesn't have power.
  3. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    Kiwi1968 (29th April 2020)
