Page 946 of 1057 FirstFirst ... 944945946947948 ... LastLast
Results 9,451 to 9,460 of 10566
  1. #9451
    Guys, was under the passenger side front dash area today and noticed the fan has come adrift from a heater box - I am guessing. What would cause this - the foam is perished, at the interface of the two boxes and everything appears firmly mounted.Attachment 80926
    Foam looks like its just perished. I think it would be quite easy to make up your own.
    PeeBee (23rd April 2020)
  3. #9452
    See the part in red...
  5. #9453
    84 Post(s)
    Easy peasy to get some slightly denser than normal foam and cut a gasket. Bin there, done that, Phil.
  6. The Following User Says Thank You to mudnut For This Useful Post:
  7. #9454
    Many thanks guys, great bunch here. I was wondering if it could just fail, but I guess I have not been in it really since the rebuild began, I would not have noticed. I will have a look at the difficulty of getting a home made jobbie installed, however might ultimately default to a factory. Mark, is that pic from the overseas website or a local aussie buy from Nissan?
  8. #9455
    Hey Phil, I think it is fairly comon for the foam to disintegrate with age. Mine was pretty shot when I did the rebuild just used some door sealing strip stuff from bunnings seemed to work well.
  9. #9456
    That is from the Nissanfast program. The part number is at the bottom of the pic. I checked the part number and it seems to be discontinued. If you ring your local Ni$$an stealer and get them to check if there's any still available from any dealers.
    PeeBee (24th April 2020)
  11. #9457
    I did the same with my GU when I had to change the heater core. I just used the door seal stuff from Bunnings as mine were pretty shot aswell.
  12. #9458
    Thanks Mark, I have some 20mm soft draft seal so with shove that in and see how it goes.
  13. #9459
    May 2016
    lower west victoria
    30 Post(s)
    Tested the old soft-roaders coils out this afternoon hauling a massive 2,000L of 78% N7, 21% O2 and a small mixture of some other crud :-)
    Love that ute MB, looks great.
    How come the tanks are on the tool boxes???
  14. The Following User Says Thank You to 10G For This Useful Post:
    MB (28th April 2020)
  15. #9460
    482 Post(s)
    Was just being silly 10G mate.
    Had to cart em home empty for Pony trough tanks.
