looking great mate, i had the same setup in my patrol. fyi, under the fridge there are some grub screws for permanent mounting. not sure if your design allows for access to those screw holes but one thing i did notice is the seam between the top and bottom part of the fridge started to seperate when i had the strap firmly tightened.
edit: i can see yours is already separating in the last pic.
Thanks Nic. What fridge have you got. I had a good look underneath when I got it because that's how I wanted to fit it, but didn't see any screws at all. I might see if I can get some 10-20mm thick form from work and sit it between the plate and the fridge. Maybe that way I can back off the strap a little.
