Results 1 to 5 of 5
Thread: Nissan Patrol Y60 TB42E
    Feb 2020
    I am newbie here, my Y60 have TB42E and cylinder 6 injector pulse is missing, kindly help.me to get wiring diagram
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    Expert Arfa Brayne's Avatar
    Jul 2016
    All 6x injectors are fed from the same pulse. If #6 has no pulse, it is in the wiring/connector on the fuel rail.
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
    Feb 2020
    Quote Originally Posted by Arfa Brayne View Post
    Thank you so much. Kindly share me link to wiring diagram.
  5. #5
    Jul 2016
    Quote Originally Posted by haroon131 View Post
    Don't have a wiring diagram. Injector wires are green and white. All the wires for the injectors are fed of the one green and white wire in the main connector plug for the engine above the alternator.
    There is a stiff wiring loom running right next to the injectors that carries injector wiring and wires for other sensors and solenoids.
    Like I already said - if you are getting power to the other 5x injectors you have power to the injector wiring.
    You have to trace the problem wire back to find the fault, but it will be in the loom beside the injectors - so unwrap the loom and look.
    Kindly share me which country you are writing from.
