Its a Nissan! =====> Its a Keeper!! ....... Got a TD42 in it BONUS!!....... I'm a lucky bugger! I've got 2 of em!
MB (11th October 2019)
Not yet either mate:-)
What injectors good man ;-)
Replacements ex my truck ya goose! Do you still want them?
Yes please Sir :-)
PeeBee (12th October 2019)
OK, back in Melb for a day then heading north again tomorrow. Took the beast out for a run after doing another radiator burp, and 5klm out, lost all gauges on the dash - bloody hell, what now. Anyway, kept driving and its very responsive in 3,4,5. So got home, parked it up and started the search, Main 75a fuse was blown, and after an hour of searching found a hastily run cable hand slumped onto the exhaust manifold - yep that will do it. Cable ties it up and away, then replaced fuse- all good. back into the garage for another 2 week rest and then its time to start fitting up the water injection, boost gauge and diving into a complete re-wire - time for a tidy up. Starting the research into the Interchiller setups on the market as focused on keeping the EGT's low. The new radiator keeps the temps down nicely as well, combined with the soluble oil coolant.
For those wondering what the sound is like from the s/c, I think if similar to running on old jeep service cookie cutters to be honest. Its nothing like the noise from Mad max - but not too intrusive, however you know its there and its a head turner when you pull up at the lights as its whining away nicely.
I also had a leak develop on one of the injector return line hoses. Swapped out the hose, no difference, so after a bit of a hunt found the return line ex the engine to the tank had a slight kink. This was straightened out and bingo, al good.
MB (30th October 2019)
Enough is enough I reckon. I have bought a heap of wire id numbers of different sizes. I think I will basically strip from the appliance, then rerun the cables to the marshall fuse boxes, a dedicated on for IGN/ACC powered devices and the mains to the rear and another fuse box in the front. Its 'kind of grown' out of control as you have seen. I expect to be finished by 2021.
MB (31st October 2019), MudRunnerTD (1st November 2019), Rossco (31st October 2019)
That is exactly what I did in the GQ mate. Even some of my old wiring from years ago scared the shit out of me. It was way way easier to just write it off and start from scratch. I have full confidence now that all my looms make sense, are all fuse protected and are not overloaded. I assumed nothing and just ran a new line. I stripped a full wheel barrow of wire out of the GQ!!! Was liberating.
Plan well. Sub boards and distribution blocks for the win mate. Good luck. If you need a hand I'm happy to give you a day.
poindexter (1st November 2019), Rossco (1st November 2019)
