Results 1 to 10 of 12
Thread: Panhard rod fell off, replaced with road safe Heavy duty. steerings still shonky??
Threaded View
  1. #4
    If you have movement in the wheel this needs to be looked at first. it could either be the wheel bearings need re-adjusting, or the top and/ or bottom king pin bearings for the swivel hub are munted. Jack the car up and see if its just the wheel and hub that moves or if its the entire swivel hub? Remember to rock the wheel from left to right and top to bottom. Left to right can't also give the indication that the tie rod ends a worn too.
    Rossco (30th September 2019)
