Not 100% on this ....
I've read two or three times that a possible culprit could be the ambient sensor.
Apparently when this fails connection with the pump, or gets damaged , it can throw a ecu light.
This is meant to be behind the grille somewhere ,but I never found it on my car.
https://patrolapart.com.au/product/g...ir-temp-sensor
That amibient sensor is for the Ti models which have an outside temp display and climate control.
Cuppa, try just disconnecting the loom to the fuel filter and leave it off for a while. If the issue goes you know where to look...
