Results 1 to 9 of 9
Thread: New Shocks
Threaded View
  1. #8
    How do you assess if the shockers are operating correctly ? I had a new OME system installed on my patrol from new. At 50,000klm, I pulled the shocks off and found the compression rates varied considerably from side to side. I tossed them for Koni adjustable hydraulic and at 110,000klm rebuilt them- or Koni did, simply replaced the metering discs, and back to square one. The Konis have a 3 or 4 stage adjustment and I found the compression rate side to side was different by 2 clicks on the rear and 1 click on the front. For me, the results have been very different than others.
    Rob Poynter (17th August 2019)
