Page 7 of 88 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 872
  1. #61
    483 Post(s)
    Which holes did you have to drill out?
    Mine went on with out dramas.
    G’day Ralph mate, what size bolts are on your P400 beast mate?
  2. #62
    Here you go @PeeBee mate.
    Tis a bloody disgrace currently under there, please don’t judge me & me NA twactor :-)
    Thanks Mark, this is exactly what I needed. Still no response from the WA mob, think they may be licking their wounds after receipt of my scathing analysis of their performance and response. So when are you going to sort out that truck - I know I read the reply but no established timeline. You wont get to drive the family rig forever!
  3. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (20th July 2019)
  4. #63
    Bit the bullet and bought these chassis stiffener plates from PSR. May as well do them pre engineering and also safeguard the chassis. I already have weld in braces on the rear spring mounts however a little more thickness won't go astray I reckon, and certainly easier to install them when everything is straight instead of buckled and twisted.
    https://www.performancesuspension.co...front-internal
    https://www.performancesuspension.co...rear-coil-towe
    https://www.performancesuspension.co...wagon-rear-ext
    https://www.performancesuspension.co...-brace-kit-sui
  5. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    MB (20th July 2019), MudRunnerTD (21st July 2019), Rossco (20th July 2019)
  6. #64
    Next lemon. At work, thinking about the car - of course, and realised the new fang dangled water pump supplied does not have a tapping point for the return line from the heater. WTF do I do with this hose, assuming I still want a heater?new Pump.jpgold pump.jpg Top image is new pump, bottom is old setup showing the hose on left that has been removed from service???
    MB (21st July 2019)
  8. #65
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    Don't know, I'm assuming that they will be the same size as yours.
  9. The Following User Says Thank You to poindexter For This Useful Post:
    MB (21st July 2019)
  10. #66
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    .....assuming I still want a heater?
    Think I've got the solution Phil
    If you drive slow enough you might be able 2 do a low and slow brisket while driving 2
  11. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  12. #67
    Not quite the solution I was looking for, but its an option I guess.
  13. #68
    Aug 2010
    17 Post(s)
    Just trying 2 help.......
    Love your endeavor 2 go supercharger over a turbo
  14. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    PeeBee (20th July 2019)
  15. #69
    At times it feels like death by a thousand lashes, but I am sure it will work out. The annoying thing with this one is how can a company supply an upgrade kit that is non functional? I will have a look at the original water pump and ascertain what the relationship is with the hose and then see if the solution is a drill and tap of a fitting into the pump snout. Just half arsed at best.
  16. The Following User Says Thank You to PeeBee For This Useful Post:
    NissanGQ4.2 (20th July 2019)
  17. #70
    Apr 2013
    22 Post(s)
    what water pump are you running?
    Mine has the outlet for the heater, but my pump flange has 4 bolts, yours appears to have 5.
