Engine died and wont restart. Removed intercooler. I can now see the nut that connects injector pipe to injector.
Question. can i njust undo the nut so i can tell if fuel is being pumped, or do I need to dismantel things further so i can also put a spanner onto whatever that nut is screwing onto.
Im worried if i just put a spanner on the nut and try to loosen it, I will twist/damage whatever is inside the rocker cover
Dickhead, used my brains and cracked the nut other end of the line, on the pump. Undid it 3 or 4 flats, reached inside with the door open so i could watch and hit the starter,,,,,,,, not even a drop,,,,,Hmmm.
