Results 31 to 32 of 32
Thread: Fitting GU Recovery plates.
  1. #31
    May 2011
    Hey guys, so that's the left side. What about the drivers side? Is it as simple as un screwing the 3 bolts, taking the factory hook/plate off, and putting a rated recovery plate on? There should already be some welded in captive nuts right?
  2. #32
    Quote Originally Posted by Shazz View Post
    Hi Shazz and welcome, yes drivers side is easy just undo the old hook thingy and bolt on a plate
    the LHS will require dropping the bullbar,drivers side has captive nut passenger side just the holes.
    Also pop over to the intros when you get a chance ,polite and all, no harm done though
    What year is your Patrol??
  3. The Following User Says Thank You to threedogs For This Useful Post:
    juzzs8 (7th July 2019)
