Hi all my gearshift is loose I think !
I think I think , so what's in the shift ? I am not sure if its a feature .
its just as not as positive as I think it could be . maybe . not sure what to expect .
pretty much theres a ball section on the gear stick which sits in a nylon bush. Then in the top of the box the the gearstick sits in the selector. There is also a nylon bush in there. Easier to replace, a bit time consuming though as the centre console needs to come out. Then you remove the circlip holding in the gearstick and the whole lot simply pulls out.
These two bushes are the only thing that wear out. There is a spring in there that keeps the tension on the stick into the box, this can break, but very rare...
Tip12345 (23rd April 2019)
if I change gears a bit quick it gets in knots ! I will take it to bits and have a look thanks
my shift is just a bit vague . the truck only has 140.000 km . I will pull the top off it and have a look . I will keep an eye out for another Nissan Patrol and have a feel ! ... Wont that go down well !! Hi can I have A feel of your gear stick !!! wish me luck
threedogs (24th April 2019)
well I have had A feel of another nissans gear shift !!
Mine does not centralise a bit like there is a spring broken or something . Any ideas ?
I did the download the manual thing and cannot get it to work .... anyone go a picture of the gearshift assembly . thanks to all
Circled in red are the two bushes you get in the kit and the spring which is sold separately, this rarely breaks or loses tension, but it can. Theres nothing to it really. Even the circlip that holds the lot in could have snapped maybe
Tip12345 (30th April 2019)
thanks now I know what I will be doing this weekend ! thanks again
