Results 31 to 32 of 32
Thread: First car GQ Coil Cab
  1. #31
    Quote Originally Posted by JackoGQYoot View Post
    snip... Dont know of anyone else has tried this?I threw a fibreglass turbo blanket on today and wrapped the dump pipe in exhaust wrap. Made a huge difference in water temp. The underbonnet temps are way cooler now as well.
    One thing to watch doing this tho... do you have a Turbo Timer fitted?
    Yes, the underbonnet temps will be way lower but the Turbo will run significantly hotter and spike on shutdown.
    The heat is still being generated but more is now being held in the Turbo and only dumped via the exhaust.
    It will be important to idle down the engine esp if it has been on load before you switch off
  2. #32
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    yeh TET I usually let it idle for 2 minutes or so before switching off.
    Got my boost controller today...What is that second piece that comes with it by the way? can anybody tell me?
    Td42 coily
