Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 88
Thread: Going Solar on the GU wagon
  1. #51
    Is that a wet cell battery? inside the cabin? Not a great idea. I had a calcium wet cell crap out and it filled the cabin with fumes and that means corrosion - yet to get a handle on the potential of what slow creeping damage I have to the electronics inside the car. Cleaned out @MudRunnerTD sinus's!!!!
    Hideous indeed. If that is a Wetcell in the car then you need to rethink that for sure. I remember the day that was venting into the car. OMG! was terrible. Also another forum member @matfew had a wetcell explode in the back of his GQ on the way to Licola a couple of years ago. it was in the rear area and his daughter was in the back seat. he was Very Very lucky.
  2. #52
    If you're up Deer Park way I have too Rhino aero bars you can have,
    You can even install a light bar underneath.
  3. #53
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hmmm, it's sealed maintenance free battery, So whats wrong with that ?
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  4. #54
    Nov 2011
    Rupanyup, 3388, VIC
    Cheers thanks for the offer, the aluminium tubing is very strong and my custom made roof brackets will do the jobs as not much weight in all .
  5. #55
    Quote Originally Posted by altech View Post
    If its a lead acid battery even though its sealed it will have a breather. As far as I understand. As when charging the battery will need to vent off the poisonous gas it will, create. If the battery is housed in a box with sufficient ventilation to the outside of the vehicle then it might be good to use.
    rusty_nail (19th March 2019)
  7. #56
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Can I just add something here. That battery is not sealed , back then Century didn’t have a sealed battery. They fitted a fake long cap over the actual battery caps. It’s hinged
    If you lift it up with your fingers, you will see the 6 caps. Open them up and check the water level because a lot of these batteries run dry prematurely, killing them.
    Century now have a proper sealed version but it still vents and should not be used in a confined space.
    Agm, Gel or Lithium are the only safe options to be used inside a car/ caravan.
    After 30+ years selling batteries I have learnt a trick or 2
    Proud BTrol Owner
  8. The Following 6 Users Say Thank You to Yeti's Beast For This Useful Post:
    Bidja (19th March 2019), Clunk (20th March 2019), Hodge (19th March 2019), jack (19th March 2019), MudRunnerTD (19th March 2019), mudski (19th March 2019)
  9. #57
    Nov 2011
    Rupanyup, 3388, VIC
    Proud BTrol Owner
    can't fine any caps on top , just a glass indicator saying good to go. anyway thanks for everone input and l have ordered a deep cycle sealed battery that is safe inside the cabin , here the link
    https://www.aussiebatteries.com.au/b...-cycle-battery
  10. The Following User Says Thank You to altech For This Useful Post:
  11. #58
    Aug 2016
    Jimboomba
    4 Post(s)
    Very good
    That’s heaps safer than having that time bomb in the back.
    Check out this video and see if your old battery is like this one
    https://youtu.be/r4StoOMsrBw
    Proud BTrol Owner
  12. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    altech (20th March 2019)
  13. #59
    There will be a vent hole, maybe only 1mm diameter. If you are lucky they will be a vent with a small diameter spigot, so you can slip a plastic hose on to vent externally. My big wet cell - also maintenance free had this however I didn't see it until after the event. I think I simply had the wrong battery for the duty - guessing the cells themselves could not take the vibration and collapsed? Anyway, its just a situation to be aware of and if you can sort something out for normal venting I guess thats your call. My lesson is learnt and never again!
  15. #60
    177 Post(s)
    Some great feedback and suggestions here in your setup mate. Yetis Beast helped me out big time with batteries / suggestions. Knows his s#it.
    I will reinforce what Mudrunner said.
    Get some proper bigger and thin stranded auto cable mate.
    Think of your current setup as fieries turning up to fight a fire and only having your Bunnings 10mm garden hose as a pressure supply.
    DC electrons don't like being pushed through long solid metals (larger strands).
    Even if you don't need high amp demand, still helps heaps having larger cables making sure it is properly fused to size / demand.
  16. The Following 4 Users Say Thank You to Hodge For This Useful Post:
    altech (20th March 2019), MudRunnerTD (20th March 2019), threedogs (20th March 2019), Yeti's Beast (20th March 2019)
