Results 1 to 10 of 23
Thread: iPad moulded to Centre Facier
Threaded View
  1. #19
    Nov 2018
    Finally got the Air Con Unit in the spot needed, had to shorten the cable to it though and drill a hole for the wire to pass through so it didn't restrict the movement.
    pulled apart a usb car charger and wire it up to be permanently sitting behind the Ipad on and wired on ACC.
    Ill probably be redoing the shroud around the CD player, air con unit and cut out the holes for the rocker switches.
    Video below showing it installed and fully functional.
    https://youtu.be/TW_Xx_abJcY
  2. The Following User Says Thank You to Wilkie_4x4 For This Useful Post:
    rusty_nail (14th January 2019)
