Page 8 of 18 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 172
Thread: Back in a GQ
  1. #71
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Dont ya just love it when what you thought should be a quick simple job turns into about three whole saturdays work!!
    Td42 coily
  2. The Following 2 Users Say Thank You to JackoGQYoot For This Useful Post:
    MB (9th January 2019), Reddave (30th December 2018)
  3. #72
    Dec 2012
    Work
    Quote Originally Posted by JackoGQYoot View Post
    Pretty normal for me mate, all part of the process, these things like to test my patience!!
    Just another Blue over Silver GQ with another TD conversion
  4. The Following User Says Thank You to Reddave For This Useful Post:
  5. #73
    Dec 2012
    Work
    Finally got to drive it today with the new turbo, it’s a completely different car now, making boost from 1100rpm now!!
  6. The Following User Says Thank You to Reddave For This Useful Post:
  7. #74
    Dec 2012
    Work
    Fixed the dry solder joints on the clock today, mounted my UHF under the radio in the DIN slot, wired up my front speakers.
    I have to make new door trims tomorrow as even with spacers I can’t use the window winders
  8. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    MB (13th January 2019), MB TD42 (14th January 2019), PeeBee (12th January 2019)
  9. #75
    Dec 2012
    Work
    Made new door trims today, 3mm MDF panel covered in marine carpet, just have to do the rear doors now!
  10. The Following 4 Users Say Thank You to Reddave For This Useful Post:
    MB (13th January 2019), MB TD42 (14th January 2019), PeeBee (13th January 2019), Rossco (13th January 2019)
  11. #76
    Dec 2012
    Work
    Went away on a shakedown solo run last weekend, started at Kendal’s campground at Rubicon, cut through to Big River, cooked some burgers and went to bed then headed home Sunday.
    Had an annoying rattle start around 150km in
    Found the exhaust had rattled loose where the front engine pipe bolts on under the gearbox, I’m hoping that it was left loose when my Exhaust guy connected my dump pipe
    But apart from that the car was faultless!!
    Fitted up some radius spacers, new radius bushes, adjustable front and rear panhard and some longer trailing arms
    I’m taking my kids away this weekend trying to fine tune the camping setup and get some reliability sorted before Labour day weekend
  12. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    MB (24th January 2019), mudnut (24th January 2019), PeeBee (23rd January 2019)
  13. #77
    Dec 2012
    Work
    Took my boys away over the Australia Day weekend, it was one of my good mates boys first camping trip so just an overnight stay at Big River.
    Then pulled my bonnet off to Dynamat the inside after cutting all the reinforcing to fit the scoop, closes with a thud now
    Redid all my rear electrical, moved my Engel plug onto the cargo barrier, tidied up the lead so it doesn’t get caught in the drawer, then my wife got happy with the label maker!
    All in preparation for: Gullwings!!
    Ordered some Emuwings today, will make the back so much more spacious!!
  14. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    AB (11th February 2019), MB (11th February 2019), Touses (12th February 2019)
  15. #78
    Would love a set of gullwings!!
  16. The Following User Says Thank You to AB For This Useful Post:
    Reddave (11th February 2019)
  17. #79
    Dec 2012
    Work
    I don’t think they’re that expensive, I started working out what it would cost me to make something that resembled a finished product and decided my time is worth too much to spend at least a weekend trying to make them!!
    I also worked out that I might work too much
  18. #80
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Good build! I like the idea of these gullwings. Has anyone had them for any extended period? Do they weather well and handle a good rain?
  19. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
