Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 88
Thread: Going Solar on the GU wagon
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    All Good , I'm hear your concern's and are going to put a pack rack bars on each end and bolt on to bars, just going to find something to suit the same profile height as the solar panel because I still want to get the patrol in the doorway of garage. this is why I haven't gone for a luggage type rack system that I wouldn't have the need for one in the first place. p.s. Car not moving on any trip in near future. the Solar system was to keep it alive. cheers Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  2. The Following User Says Thank You to altech For This Useful Post:
    GQtdauto (3rd December 2018)
  3. #12
    198 Post(s)
    Good news Alex, glad we could help. Phil
  4. The Following User Says Thank You to PeeBee For This Useful Post:
  5. #13
    snip...while we were on our trip earlier in the year I heard there was a fatality near Cairns? From a solar panel coming adrift and going through a car window .
    Yes, you are correct.
    Happened around the middle of the year on the Bruce Hwy in FNQ.
    Solar Panel flew off a Caravan and went thru the Windscreen of a Car.
  6. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Bidja (3rd December 2018), GQtdauto (3rd December 2018)
  7. #14
    Crikey, that’s truly horrible to hear gents!
    Slightly off track but an old surfer mate and I as ‘P’ platers accidentally speared a following cars windscreen with his lightweight fiberglass board on a 100kmph freeway in our 20’s. Have never used ‘Octopus Straps’ ever again and thankfully she was tailing us passenger less as it penetrated through to near the head rest position, scary scary lucky stuff for all involved that day :-(
  8. The Following 2 Users Say Thank You to MB For This Useful Post:
  9. #15
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Quote Originally Posted by altech View Post
    Alex, as you have glued the module down, guess it will stay (no air gap), not the best for cooling but they also can get pretty hot mounted to an iron roof (shed or house).
    Think of maybe getting 4 gutter mount bracket (steel) similar to those used to mount/attach(bolt) to the ARB roof rack and modify them by under slinging a 2 lengths of aluminium hollow box section (say 40mm sq X 2.5mm), with spacers if req'd, going from the L-R hand side BRKTs (one both front and rear), passing over the top (each ends) of the aluminium panel frame extrusion and dropping down angle corner locating tabs that are attached to the aluminium rack hollow box section. This will prevent the panel from going Fwd, AFT, lifting and moving sideways. Use some rubber strip to protect frame/rack interface (no need to mechanically attach panel frame to rack box rail section).
    Gosh mate, should have read your post a bit closer as U covered most of this.. b. glasses. All good.
  10. The Following User Says Thank You to Bidja For This Useful Post:
    altech (30th March 2019)
  11. #16
    Jul 2017
    40 Post(s)
    In the time back in mid 70's had 6 sticks (3 each side) on the 74 combi roof rack with single ockies F/R each side. Things U do haha
  12. #17
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Bottom line: IF it should come loose (or when if you prefer) and injure someone, insurance will wipe you and you would almost certainly end up in court. No different from an unsecured load and there are a few examples of that available.
    It is really worth the risk - when the alternative is so simple and not very expensive.
  13. The Following User Says Thank You to Brissieboy For This Useful Post:
  14. #18
    198 Post(s)
    There is a low profile Unistrut avail that is 41mm wide x 22mm high. Brackets can be sourced from a number of roofrack places, and all you need is an adapter to tie the two together - a bit lower profile than Bidja's shot, sits maybe 20mm off the top of the roof in the centre of the vehicle. Just another possibility perhaps?
  15. The Following User Says Thank You to PeeBee For This Useful Post:
    altech (3rd December 2018)
  16. #19
    Nov 2011
    Rupanyup, 3388, VIC
    Thanks Guys for all your input , not in a hurry at moment, I think of something cheers Alex
  17. #20
    176 Post(s)
    Look at that video again. The adhesive used is not silicone, it's Sikaflex 11fc. Although sika recommend using their 252 product in conjunction with their primer, most folk find 11fc is fine for the job & much easier to use. The panels fitted to the roof of the canopy on our Patrol have no mechanical fixing, they were bolted to aluminium angle & the angle (along the 2 long sides of each panel) was glued to the roof with 11fc, with the areas of gluing having had the paint removed & pre-cleaned with isopropyl alcohol after having been taken back to bare aluminium. Most importantly (for strength/flexibility) the correct thickness of adhesive was maintained by using 3mm spacers. After 24 hours curing there is no way these would come off without the set adhesive being cut - and that would be a pretty tough assignment. Over the past 18 months they have travelled in Australia’s full range of temperatures & over plenty of rough kilometres, have been checked regularly & remain rock solid.
    I'm sorry but I have to agree with others about the use of silicon & mounting on to paint. I wouldn't want to be travelling behind your car! I know it’s a pain, but the only safe thing to do is to remove the panel & start again. Live & learn!
    When you do, I'd suggest that in the interests of solar panel efficiency, & the chance to kill two birds with one stone, that you increase the gap between panel & roof a little (25mm'ish). It will help to keep the panel cooler (& thus work better - probably only important if you will use the battery for anything else other than starting) & in a small way will help to keep the vehicle a tad cooler inside by creating a 'tropical roof '.
  18. The Following 5 Users Say Thank You to Cuppa For This Useful Post:
    Bidja (4th December 2018), clawrence (4th December 2018), MB (4th December 2018), rusty_nail (4th December 2018), the evil twin (4th December 2018)
