Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: What are good brand air intakes ?
    Expert First Pooy's Avatar
    Mar 2018
    I am looking at a K&N air intake for my TD42 Gq it is 2nd hand for $250 but I can not contact K&N to see how much a new one is to see if it is a fair price
    Do you mean a filter or an airbox? got a pic or a link mate
    Expert Bulbous's Avatar
    Apr 2011
    Dubai
    I used to run a K&N, but now switched to AEM because they're dry and so much easier to maintain https://www.aemintakes.com/search/univcone.aspx.
    Steve
    2011 Patrol Safari 4.8 (Fitek)
    Quote Originally Posted by Bulbous View Post
    Cool are you just chasing a Pod then? i ahve a couple of K&N Filters for a GU TD42 Airbox id be interested in selling as i have changed airboxes and have no further use.
  5. #5
    Mar 2018
    Here is what I was looking at
  6. #6
    Mar 2018
    How do you clean a K&N then ?
  7. #7
    22 Post(s)
    Quote Originally Posted by First Pooy View Post
    With Detergent and water.
    It's good to have 2 So you can swap them out without the need to give up the car for a few hours
    96 GQ coil/Cab
    08 G6eT
  8. #8
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    $250 for air box in pic with pod filter is pretty good (in good condition?) but need 4" thru to be worthwhile. Looks like maybe offset pod filter or outlet pipe set off at angle. Get K&N 9"pod filter (straight flange) for $85-115. Bought K&N (KNRE-0890) today eBay $85.00.
    Some more specifics on filter box type/design and pod type?
  9. #9
    Mar 2018
    I didn't know alot about it,I was asking questions but the guy got upset with them it is a 4 inch but now that you have pointed it out yes the out let from the box is on a 45 degree bend is the striaghter the better for air flow,he cliamed he got about 240 hp out of it
  10. #10
    Jul 2017
    40 Post(s)
    The bend is fine, it looks like it provides for good flow. Rule of thumb good idea to have at least 30mm o/a clearance between filter pod outside profile to box internal faces and to not obstruct/causing restriction to the in flow (less obstruction the better. Did he give U a brand name? Does it come with serviceable pod filter?
    240 hp require good flow, ask him why he is changing out.
