Results 1 to 10 of 19
Thread: Should I buy this Patrol?
    Oct 2018
    Hey just wondering on your guys' thoughts.
    I've found a 1993 GQ Patrol TI with a tb42e engine and 320,000k's. https://www.gumtree.com.au/s-ad/stot...ail/1198031338
    I went and had a look at it, the inside door trims are missing, seats are ripped, there was oil around radiator under engine block, on top of diff and around front brakes. After jump starting it, the engine sounds good, no knocks, no visible radiator leaks, all fluids were fine except the owner mentioned it needs steering fluid, engine was reconditioned in 2014 and I couldn't find a spot of rust.
    So it'll need new seats, door trims, battery and steering fluid.
    She needs a bit of work but rust free is a big bonus. Price seems about right would be a good little project, give it some love and should come up alright.
  3. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    GQtdauto (22nd October 2018), MrAwesomer27 (22nd October 2018)
    84 Post(s)
    Give it a compression test and cooling system pressure test. If they are ok and If you can score another interior for cheap, then go for it
  5. The Following User Says Thank You to mudnut For This Useful Post:
    Oct 2018
    I bought it for $1000, and drove it an hour home, it was all good.
  7. The Following 5 Users Say Thank You to MrAwesomer27 For This Useful Post:
    jack (3rd November 2018), jay see (3rd November 2018), PeeBee (4th November 2018), Rossco (3rd November 2018), Touses (5th November 2018)
  8. #5
    Quote Originally Posted by MrAwesomer27 View Post
    Hey matey...instead of steering fluid as a need..download the manual...i rebuilt mine in a coiple of hours...easy as....no more oil n cheap to fix....congrats on 5he new 4b to hwy
  9. The Following User Says Thank You to Avo For This Useful Post:
    MrAwesomer27 (4th November 2018)
  10. #6
    Oct 2018
    I've downloaded the service manual, do you mean rebuild the power steering?
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  11. #7
    Yeah if it is leaking oil...it is an easy fix
  12. The Following User Says Thank You to Avo For This Useful Post:
    MrAwesomer27 (5th November 2018)
  13. #8
    Oct 2018
    Turns out it was bad hose clamps and split lines, so I replaced hose clamps and cut the line shorter. Now it doesn't feel like I'm steering a ship.20181112_113056.jpeg20181112_113033.jpeg
  14. The Following 2 Users Say Thank You to MrAwesomer27 For This Useful Post:
    Avo (12th November 2018), GQtdauto (12th November 2018)
  15. #9
    Oct 2018
    Turns out the problem is still there, it keeps blowing clamps and it's split two hoses. Any ideas, the Power Steering works for a bit then it blows and all the fluid leaks out.
  16. #10
    Buy new lines? Cutting and reclamping old split lines doesnt surprise they split again.
    Gong him Red!!
