Results 1 to 10 of 17
Thread: Odometer correction
    Expert dpetersen's Avatar
    Jan 2015
    Watarrka National Park
    6 Post(s)
    Odometer correction
    Hi all!
    My odometer has been out since I purchased the car but has gotten worse (obviously) since fitting 33s today.
    Today I drove 100ks and it only registered as 91.7ks.
    I don’t have a gps so I couldn’t check the speedo but am I correct in saying that if I was doing 92kph on the speedo that I’d actually be travelling at 100kph?
    What’s the best way of fixing this?
    Don’t get me wrong it’s a good way of keeping the Ks down on the car lol but probably isn’t the right thing to do.
    Patrol is an 2006 4.2 wagaon.
    Cheers guys
    2006 4.2 tdi wagon
    Plenty more to come!
    176 Post(s)
    Hey mate. Don't know about correcting it ....
    But mine is same as yours.
    If my needle is on 91-92. I am actually doing a 100. Verified via 3 different gps units.
    2005 4.2 on 33s..
  3. The Following User Says Thank You to Hodge For This Useful Post:
    dpetersen (1st November 2018)
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    There is a thread here somewhere for correcting a GQ speedo not sure about other models , putting 33's on does alter the speedo but I've gotten used to it .
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Jaycar sell a speedo corrector if you do want to make it read accurately.
  6. The Following User Says Thank You to Brissieboy For This Useful Post:
    476 Post(s)
    With the GU's its easy mate. You can just change the speedo driven gear on the sensor. If you pm me the VIN of your car I can look up how many teeth is on the gear you have and should be able to point you to what you need to buy. The right gear should cost you under $50.
  9. #6
    Jan 2015
    6 Post(s)
    Thanks mudski, will send you a pm
    2006 4.2 tdi wagon
  10. #7
    176 Post(s)
    The table in this thread may help.
    https://r.tapatalk.com/shareLink?url...3&share_type=t
  11. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    dpetersen (2nd November 2018), Rossco (28th March 2019)
  12. #8
    Patrol Guru TimE's Avatar
    Canberra
    Yep, I have a 4.2 with 3.9 diffs on 33s. I use a 15 tooth cog at the gearbox end of the speedo cable. Speedometer is spot on with the 3 GPS units I have used.
  13. The Following 2 Users Say Thank You to TimE For This Useful Post:
    dpetersen (2nd November 2018), Hodge (2nd November 2018)
  14. #9
    Jun 2018
    25 Post(s)
    I'm interested in a solution for this issue too, as I think my speedo is about 10% out with 33's on my GU III.
  15. #10
    Quote Originally Posted by dpetersen View Post
    X 2 with Mudski an easy fix these days, must set up my GPS and try as well
    I set my cruise control on 107 for a 110 speed on the HWY.
    Think mine is right with 285s but will check.
    One of my GPS has reverted to the the Nth hemisphere, a Garmin 12
    the other is a VMS tourer. dont use them ppl always tell me where to go ha ha ha
