Page 16 of 109 FirstFirst ... 1415161718 ... LastLast
Results 151 to 160 of 1088
  1. #151
    Scored a bargain on some Beaut Blue Swimmers!
    7 minutes light salt water hard boiled then straight into iced water before topping our Spaghetti Marinara for two, sweet little rippers!!
  2. The Following 5 Users Say Thank You to MB For This Useful Post:
    Avo (26th September 2018), Clunk (25th September 2018), PeeBee (25th September 2018), Rossco (28th October 2018), Woof (28th October 2018)
  3. #152
    Picked up a little Weber BabyQ thingo for those upcoming summer fire ban days out there.
    First test run underway at home, just squeezes 2.5kg of quite meaty beef ribs on its trivot.
    Any tips/advice on these things @Winnie mate, I’m struggling to keep it under 150C let alone the hoped well below 100C slow cook.
  4. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (28th October 2018)
  5. #153
    You will struggle with that mate its not rally what they are designed for. We use ours at least 5 nights a week all year round, oven in the house does not get used. Love the weber q!
  6. The Following User Says Thank You to Winnie For This Useful Post:
    MB (28th October 2018)
  7. #154
    Cheers mate, I’ve wedged the lid open some 3” and dropped about 10C. They are pretty cool little things, will keep playing around with it but as you’ve kindly mentioned, best as a normal oven or grill for sure can imagine. Noticed they had a rotisserie extra thingo for sale might look into down the track too
  8. #155
    177 Post(s)
    As Winnie mentioned @MB , they're not very good at slow cooking. Closed temperature chamber effect gets too hot with the size of the burners underneath. Iove ours and we barely ever cook any meat in the kitchen now. The Weber is the go. Timing is everything. Warm it up shut the lid, walk away.
  9. The Following User Says Thank You to Hodge For This Useful Post:
  10. #156
    Cheers Hodgey mate, I’ve taken battle stations, meat internals hit 60C, shut her off now and triple foil resting inside it for another hour or two tucker time.
    Going to get the Milwaukee drill and sort this puppy out later with some valves
  11. The Following User Says Thank You to MB For This Useful Post:
    Hodge (28th October 2018)
  12. #157
    Did the wood chips get smoking? Good idea that one!
    Good for baking too, done a few desserts in it before and scones as well.
  13. The Following User Says Thank You to Winnie For This Useful Post:
  14. #158
    Alrighty, problem solved for next time!
    NEW & Improved ‘Weber Unicorn Series’ ;-)
  15. The Following 4 Users Say Thank You to MB For This Useful Post:
    AB (28th October 2018), PeeBee (28th October 2018), Plasnart (28th October 2018), Woof (28th October 2018)
  16. #159
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Y
    U
    M
    Hello from Under Down Under!
  17. The Following User Says Thank You to taslucas For This Useful Post:
  18. #160
    The warranty instructions said absolutely not to add potentially flammable chips or the like...I read afterwards....still alive thankfully
