Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Lost Boost?
    Oct 2016
    Sydney NSW
    So can this be welded until I find a replacement?ED31FCD0-29F5-43C3-8D40-5D4A70C89790.jpeg
    NED The Iron Outlaw, 2006 GU Manual ZD30Di.
    465 Post(s)
    Just block of both ends where they mount up and be done with it. If it were me, I would block both ends and bolt that broken pipe back up just incase mr plod pulls you up and notices its missing. Big fine.
  4. #13
    Oct 2016
    Sydney NSW
    Will it effect the EGR sensor? Already blocked the one that goes to the manifold.
  5. #14
    465 Post(s)
    Quote Originally Posted by Pj-14 View Post
    No. So just get a plate for the other end, they are shaped differently, then put it all back together.
  6. #15
    Oct 2016
    Sydney NSW
  7. #16
    465 Post(s)
    Thats the one that broken correct? If so block it off at the top, which you already have, and also block it at the bottom, and put the pipe back on as normal and ignore the fact that its broken. It will just be there for looks now.
  8. #17
    Oct 2016
    Sydney NSW
    Yes top (arrow)pipe is the broken one, so just block those ends and alll will be good?
