Results 1 to 10 of 20
Thread: Coolant issue
    Expert tassie wombat's Avatar
    orielton,tasmania
    Coolant issue
    Gday all, about a month ago I gave the wagon a bit of a birthday and replaced the rubber hose that goes from below the thermostat housing to the bottom of the expansion tank, and also replaced the water pump. Since doing these 2 things I'm constantly topping up the expansion tank ( where the recovery cap goes) and the autron temp gauge seem to fluctuate more than it used to ( not over heating) what's everyone's thought?? I keep thinking that there may be air stuck in there somewhere?? Its an '04 td42, and I've just done over 4000ks over the last 2 weeks, from Tassie to coffs harbor via Dubbo, then back down the coast, I'd have thought that any air would have come out by now??Thanks in advance.
    483 Post(s)
    Coolant issue
    G’day mate, in regards bleeding the system they do like to have the front end raised a bit to assist. (Gutter parked or jacked up) I also have used a 1.25L upside down 1/2 Coke bottle and some tape to snuggly fit the radiator for filling. Keeps the water filling level higher and you can watch the bleed occurring easier. Cheers!
    EDIT: 50/50 Bursons own brand green coolant seems to work fine for ours.
    orielton,tasmania
    Thanks for that mate, I used a "no spill funnel when I re filled with coolant which sits up fairly high?
  4. The Following 2 Users Say Thank You to tassie wombat For This Useful Post:
    GQtdauto (14th October 2018), MB (14th October 2018)
    483 Post(s)
    Sweet, bit fancier than my Coke bottle mate although not sure if it is a sealed connection to trickle raised coolant in with each burp over say 30mins.
    The raising of the vehicles front end apparently helps sneaky hidden pockets of air work their way out too.
    orielton,tasmania
    I'll try jacking the front up and rather than having the funnel on the expansion tank ,I'll put it directly on the radiator.
  7. The Following User Says Thank You to tassie wombat For This Useful Post:
    483 Post(s)
    Yep, that’s the go mate, fingers crossed for ya it’s an easy fix hopefully. Please do keep us posted on outcome, others better will surely assist if it’s not solved. Cheers!
    orielton,tasmania
    Thanks mate 👍
  10. The Following User Says Thank You to tassie wombat For This Useful Post:
  11. #8
    Coolant issue
    Get onto eBay and buy a coolant bleeder. I think they are around $30 or so. Best thing I have in my shed. Use it heaps.
    Sent from my crapPhone using Tapatalk
  13. #9
    orielton,tasmania
    Get onto eBay and buy a coolant bleeder. I thought no they are around $30 or so. Best thing I have in my shed. Use it heaps.
    Thanks mate I'll have a look
  14. The Following User Says Thank You to tassie wombat For This Useful Post:
  15. #10
    orielton,tasmania
    Judt had a look on Ebay and the only thing I could find in regards to a coolant bleeder were bleeder screws ?
  16. The Following User Says Thank You to tassie wombat For This Useful Post:
