Results 1 to 10 of 15
Thread: SRA Free wheeling Hubs Pulled Apart
    Jul 2010
    Waterford West Qld
    Ok bear with me Im not sure how to do this type of thread, but could everyone not post anything here until I complete as it will be a lot of pics and explanations.
    Tim
    Jul 2010
    Waterford West Qld
    The above shows you six Tiny allen cap bolts that allow you to remove the free wheel lock plate. This will allow you access to the 8mm allen cap bolts to remve the free wheel hub. Before undoing those, wipe grease fom around axle shaft as far down as you can reach. You will see a snap ring that needs to be removed with a pair of circlip pliers and tiny flat blade screw driver.
    Then you can undo the bolts and slide off hub.
    Jul 2010
    Waterford West Qld
    Behind the hub you will find a thrust bearing and thrust plate. (bearing not shown here)
    Jul 2010
    Waterford West Qld
    Then behind those are the Bearing lock nut keeper and bearing lock nut. You will be able to pick the keeper out with tiny flat blade screwdriver,
  5. #5
    Jul 2010
    Waterford West Qld
    At this stage you should have the weight off the diff/wheel. On a stand etc. You may need to tap the lock nut undone (RH thread) at first. then it will spin off usually. Once that's off you will see a bearing spacer then the bearing.
  6. #6
    Jul 2010
    Waterford West Qld
    So as you can see no wheel bearing nut socket needed.
    Then we go to The HUB itself.
    Here you have the inner side of the hub complete. Remove the circlip ring under the outside lip using that tiny flat blade screwdriver again. As you can see the drive gear will become free.
  7. #7
    Jul 2010
    Waterford West Qld
    Pull the spring out, and then all you have left is the hub lock mechanism.
  8. #8
    Jul 2010
    Waterford West Qld
    This is actually a two part assembly as follows.
  9. #9
    Jul 2010
    Waterford West Qld
    all you have to do now, is clean all parts and grease it as you reinstall it.
    I have not gone into doing the wheel bearings as they will be the same as all other diffs. I have only put up this info as i could not find any info when I needed it yesterday.
    Hopefully someone will find this useful one day.
    Tim
  10. The Following 4 Users Say Thank You to Finly Owner For This Useful Post:
    AB (5th May 2011), GUtsy ute (6th May 2011), Silver (5th May 2011), YNOT (4th May 2011)
  11. #10
    Jul 2010
    Waterford West Qld
    Feel Free to post away now.
    Thanks for being patient.
  12. The Following 5 Users Say Thank You to Finly Owner For This Useful Post:
    Clunk (4th May 2011), growler2058 (5th May 2011), JoeG (5th May 2011), my third 256 (4th May 2011), YNOT (4th May 2011)
