Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Information on TB42s extended rotor button
    Banned
    GQ Patrols fitted with the TB42s (carby model) run a points type Distributor which have an overly large air gap between the rotor button itself & the distributor cap.
    This has been well none & documented to course problems. Some of the side effects of this large air gap is missing at idle & missing under load. This problem is amplified when running LPG but not exclusive.
    To combat this problem a company in Melbourne developed an extended rotor button for the TB42s points type Distributor which has been met with great success.
    Here is some pictures of the re-developed rotor button & you can find contact details at the bottom of this post.
    Extended rotor Button from Performance Ignition Services. 03 98723644
    Price is $80, inc GST.
    They do changeovers, at $35 plus $45 deposit.
    Overnight freight is from $11 if required.
    http://www.performanceignition.com.au/
    Paul
  2. The Following 3 Users Say Thank You to patch697 For This Useful Post:
    MarkGQ (25th January 2013), taslucas (17th September 2011), YNOT (19th January 2011)
    Sep 2010
    Sydney
    Do they modify the standard one ?
    Banned
    Yep thay do thats why thay work so well
    Expert Russell1974's Avatar
    were abouts are these guys?
    Banned
    Quote Originally Posted by Russell1974 View Post
    At 47/41-49 Norcal Rd Nunawading VIC 3131
    Location map
    Paul
    Well worth the money ,
    I noticed a difference in how smooth my Maverick ran as soon as i fired it up.
    90 maverick LWB 2" lift,General Grabber a/t
    92 Coil Cab 3" lift, kl71 33"s n/a td42
    Oct 2010
    Turkey
    i am from turkey, how can i buy?
    Contact them on their website and see if you can arrange to have one sent to you.
    Tony
  10. #9
    Apr 2011
    Mooroolbark
    I also found a small improvement in power (but not economy that I can measure), and the missing at idle has virtually disappeared.
    Chris
    '88 LWB TB42 Auto Dual Fuel 72/90lts 3rd gear Trans Lock-up 2" Suspension Lift Piranha Dual Battery
  11. #10
    Beginner moo_r32's Avatar
    Apr 2011
    adelaide
    Quote Originally Posted by adamsc57 View Post
    Chris
    thats exacly what im after!!
