Results 1 to 10 of 18
Thread: Check plate..
    Beginner Dads GQ's Avatar
    Sep 2018
    Check plate..
    I've seen a few rigs with check plate on the door panels. I would like to put on all the doors and possibly use for most of the trim where there was carpet.
    What is the process?
    Is this something that would be done by an upholsterer or a metal worker?
    Sep 2018
    I just realized this might not be in the right thread.
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Mate of my sons has a massive 3D printer and has printed him up some door cards for a GU ute which not only look good are as tough as nails , not sure if he does GQ or that pattern .
    Sep 2018
    That sounds pretty neat! Would be handy to find somewhere up here that could do the same. I know a steel joint that has a massive plasma cutter that could cut the material to shape and I was originally thinking along those lines. Never considered 3d printing.
  5. #5
    Where are you? My cousin produces them, he has all the templates for the different models.
    I hate the idea, it would get stinking hot in summer and burn your leg.
  6. The Following User Says Thank You to Winnie For This Useful Post:
    neet_wagon (16th October 2018)
    Sep 2018
    Hi Winnie. In Darwin mate. Does get pretty hot during the wet!
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yes might look tuff but going on a long trip especially in the heat would see you swapping them out I reckon .
    176 Post(s)
    I'd think twice about putting form over function unless it's not for a daily driver
    Just the thought of checkerplate in our ute doors makes me both sweat & shiver ............. visions of driving inside an oven ... or a fridge in cold conditions! Not to mention I reckon the higher in-car noise levels would make conversation harder.
    The 'pressed board/masonite-like' door skins from the factory probably do a fairly reasonable job of not 'drumming' or amplifying sounds. Interested to know the 'qualities' of the material used for the 3D printed skins. If their material improves on the original re heat & sound insulation and provides something more durable to boot (who hasn't had those plastic fasteners pull out of the masonite?) they'd be onto a real winner. And if better door storage is added ... could be better still.
    How much for 2 GU front doors?
  10. #9
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I'll find out Cuppa I know he has a business selling them , I'll also see if I can find the photos I took .
  11. #10
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Door cards ,has since modified the design slightly for a better fit .
