Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Scan tools
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    @jay see @LeighC
    Hi Guys.
    I have the software loaded on a Laptop and am not sure if it can be transferred to another Computer. The Nissan Consult for connection to the Obd plug under the dash worked with my 1998 4.5 L Patrol.
    I don't want to cause any problems with Software Licence
    Still available subject to Licence restrictions
    If to want to test I am available in Pakenham.
    Regards
    Bob
  2. The Following User Says Thank You to Bob For This Useful Post:
    jay see (25th August 2018)
  3. #12
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by Bob View Post
    @jay see @LeighC
    Hi Guys.
    Regards
    Bob
    As far as I am aware @Bob ECU Talk is a free program, so no restrictions. Who ever you sell / give your plug 2 can just download the software free of charge from ECU Talks website. If you have concerns about it just email Peter
  4. The Following 2 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    Bob (25th August 2018), jay see (25th August 2018)
  5. #13
    Jul 2018
    Thanks Bob, I will try to get down an see you one day but I am 3 hours away, the cable I was told I needed to connect with that worked well was called a Blatz cable but it appears it is no longer available. I would of thought if it worked with yours with the OBDII plug it would do mine, Is your an auto?
    I have tried Nissan DataScan ii (trial program) & it wont deliver all the data I need. The problem appears to be the first of the TB48DE's in a GU TI Patrol (09/2000) with 5 speed auto trans & only 2 oxy sensors. It has an OBDII socket but runs a different protocol. I want to read live data for TPS, Variable intake, MAF airflow meter, Ig. timing, & variable cam timing, driving down the road when this lean spot occurs.
    Thanks for others info & will try ECU talk also.
    Cheers Leigh
  6. #14
    Aug 2018
    Just an update. I bought this scan tool, a Foxwell NT614 and it works well with my 3l DI patrol. Cheers everyone.
