Hey mate just need the bracket off a GQ that mounts on that side. Think the later model TDs did as well as the RD28. Will bolt straight up to factory holes. Also need the brake line of the master cylinder as it bends around a little sharper. Makes more sense having it on this side as it goes across the firewall then back to the pump with the firewall mounting position. See pic below moved mine across to make room for airbox too.
