Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Looking for GQ clock plug from old loom
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I had a look through this lot but no luck..
    John
  2. #12
    198 Post(s)
    Thanks for the supreme effort John, I will contact PAP on monday and see what they can offer.
  3. #13
    Advanced Flex's Avatar
    Sep 2011
    Melbourne, Australia
    How did you go finding a plug?
  4. #14
    198 Post(s)
    Quote Originally Posted by Flex View Post
    Crapped out, tried two Patrol Wreckers and they either didnt have a loom or were not prepared to chop one unless I paid for the entire loom, which is understandable. I found the plug a bit loose earlier this week and pushed it home, but the clock is still irratic at best, comes on when it feels like it. I have a replacement but really want it on all the time.
  5. #15
    I'm telling ya mate the plug won't be the problem. It will be dry solder joints inside the clock which would be a quick 20min fix.
  6. #16
    Sep 2011
    You sure it's the plug, not the clock playing up. Nearly all gq clocks fade away and need to be soldered internally.
  7. #17
    198 Post(s)
    Yeah, will do the fix when I get time, but I still want the clock on all the time and doing any wiring changesin the super small area is a pain so want a plug with tails so the mods can be done on the bench and simply installed.
  8. #18
    198 Post(s)
    OK, did the solder job, took 15 minutes, then without a suitable plug, I went to jaycar and bought a packet of 4mm push on terminal, connected the acc and power wires together, ran a seperate earth, bogged up the plug cavity with silicone to ensure there is nothing coming apart, and bingo, clock on all the time, nice and bright. thanks guys, easier than I thought.
  9. #19
    Dec 2012
    Work
    If you’re still after a plug I removed a loom from my GQ today, you’re welcome to come and snip plugs off in Ferntree Gully
    Just another Blue over Silver GQ with another TD conversion
  10. The Following User Says Thank You to Reddave For This Useful Post:
    PeeBee (12th August 2018)
  11. #20
    198 Post(s)
    Quote Originally Posted by Reddave View Post
    Thanks dave, give it a pass, all done for now.
    Reddave (12th August 2018)
