Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Y60 Bonnet struts and brackets
    Aug 2017
    Victoria, Eastern Suburbs
    hi all,
    I have managed to create a set of brackets, LH and RH, using existing mounting points (no engineering required) which eliminates the need to use the existing bonnet bar/pole. Have mounted the brackets on a number of other GQ's successfully and was wondering if there is a market for them. The struts are not GU ones and have been tested to go with the brackets specifically.
    At best it takes about half hour to fit....at worst an hour. The most expensive part are the struts as they will be brand new and ordered to suit.
    Cost will depend on numbers.
    I would say there would be mate..... What would an approx ball park figure be?
    Aug 2017
    If it is a one off about $150- approx. Haven't worked out postage and handling yet. Posted an imagebonnet bracket7.jpg
  4. The Following 2 Users Say Thank You to 94patrol For This Useful Post:
    Clunk (31st July 2018), pluhart (28th December 2018)
    94Patrol, could be interested however I think the strut will hit my aux battery which is right up near the firewall. Are you able to take a front shot pls so i can assess. I have a bit going on under the hood on both sides already so maybe these won't fit - if they do i will be up for a pair.
    Aug 2017
    hi PeeBee, the compressed length is 215mm when closed it sits just below horizontal following the quarter panel line. hope it helps. Here's a front on. bonnet bracket8.jpg
  7. The Following 5 Users Say Thank You to 94patrol For This Useful Post:
    AB (31st July 2018), Clunk (31st July 2018), JackoGQYoot (31st July 2018), PeeBee (31st July 2018), pluhart (28th December 2018)
    Many thanks, will have a close look tomorrow.
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    I would definitely buy some of these but I'm in WA so shipping would need to be factored in.
    Td42 coily
  10. #8
    Aug 2017
    Hi JackoGQYoot, if you are a definite I will look into shipping etc.
  11. #9
    I think they would be a really tight fit if they fitted at all. I will pass for now, but great idea and thanks for the images.
  12. #10
    Aug 2017
    cheers...no worries
