Page 1168 of 1467 FirstFirst ... 11661167116811691170 ... LastLast
Results 11,671 to 11,680 of 14662
  1. #11671
    22 Post(s)
    I think you are pretty close. I am guessing its not the bolt but that small projection on the corner plate. I will have a look tomorrow to see if the shocker will compress that much and let you all know. Absolutely gobsmacked if it is as would never have thought I would get that sort of travel out of this suspension. If it is I am going to do some surgery/radius the plate I think as these are too expensive to go tearing apart!! Thanks Ben, Bidja and MB!
    It would be a good idea to find a flex ramp or a fork lift to flex it up and look for and contact. Ideally a hoist and remove the the springs and cycle the suspensions full range of motion and be able to watch it. To me it lt looks like the shock is contacting in 2 different places. The stone guard and right at the base. 2 different points of contact at 2 different points in the suspension travel. (How I see it anyway)
    96 GQ coil/Cab
    08 G6eT
  2. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    MB (12th July 2018)
  3. #11672
    Ben I think your observations are really good. I am a bit mystified about the bottom ding though, so will have a closer look and see if i can find the witness marks.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (12th July 2018)
  5. #11673
    22 Post(s)
    It'll be the same spot judging by the orientation of those marks, my guess is at full extention, when Installing big bore shocks you cut away the back of the bump stop pad which has been replaced by the airbags mount to clear the bigger bore shocks
    Remember that when articulating, at full droop on that side, the lower control arm is swinging down and forward towards the front axle. The upper control arm is doing the same, but because it's shorter it is rotating the diff therefore the pinion downwards. At the same time the panhard rod is swinging down and pulling the diff towards the drivers side because it moves on a perpendicular axis. That's why when stuff has been hitting and is inspected at ride height, the marks dont seem to make sense
    96 GQ coil/Cab
    08 G6eT
  6. The Following 5 Users Say Thank You to Ben-e-boy For This Useful Post:
    AB (12th July 2018), Bidja (12th July 2018), MB (12th July 2018), Rossco (13th July 2018)
  7. #11674
    This is what I love about this forum, clear knowledgeable feedback, really had no idea what was going on, no enlightened. Thank You.
    MB (12th July 2018)
  9. #11675
    483 Post(s)
    So....Action Plan?
  10. #11676
    Confirm interference points first, then knock the corners off the brackets. Monitor from there. I dont have access to a set of super ramps or a forklift, and think since this is the first time its happened since june 1997, I might have some time up my sleeve.
    MB (13th July 2018)
  12. #11677
    483 Post(s)
    Nasty twacks they’d be brother, come again for sure :-)
    PeeBee (13th July 2018)
  14. #11678
    Well, witness marks on the bracket, so airbag has to come out and surgery to the baseplate. Interestingly there is half the clearance on the passenger side to the drivers - diff off center, adjustable panhards req? Damaged shock is rooted, won't compress by hand.
  15. #11679
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Lift more than 2", would say adjustable panhards would be needed to bring diff back to center. Would look at F/R.
    That shock took a hiding.
  16. #11680
    22 Post(s)
    Where do mean clearance? Also note that the shock mounts aren't symmetrical from factory. Look at then in relation to the hub on each side
    96 GQ coil/Cab
    08 G6eT
