Only an honest guess Phil mate! ‘Axle Hill-Burgoyne’ a little rock possibly chipped/started a fold up in there under sleeve and or aftermarket lateral shock absorber loading design. No chance that your shock mounts have ever been modified mate?
PeeBee (11th July 2018)
My stupid clutch is playing up!
Starts grabbing near the floor and goes stiff and not disengaging properly. Grrrr
Next time I stop at the lights it’s back to normal and light as a feather and grabbing 1/4 way off the floor, then back to hard and well u get the picture.
Any clues before I go replacing everything.
The clutch isn’t that old either.
Bloody cars
Not modified, just had this shocker refurbed by Koni with new valving. I guess a stone could have gotten up there, but Axle Hill is kind of bolder stuff though. Anyway I have a spare so will swap it out and assess the damage, but suspect the body is pushed inwards so will have damaged the new seals and piston I reckon.
Bidja (12th July 2018)
What is odd with this possibility is my barge is hardly a flex monster. The rear springs are 400kg constants running airbags as well. I have seen the rears compressed as far as they will go but it takes a fair hole/hump to do that - but i guess its a possibility as you suggest.
Yeti's Beast (12th July 2018)
Tube dent is worrying, maybe you have the the Raid series with larger 70mm bore, they have the twin tube design for extra protection against stones/dents. Maybe fine. Good spare anyway, new shield or cut away damaged section/crude repair.
I have the smaller Heavy Track series ($ driven at the time).
No these are the earlier series, purchased maybe 20yrs ago, well before the Raid came out. They have been rebuilt recently, good shocker, maybe 50,000klm old. I ran OME before this and they were OK, but totally rooted, loss of gas, poor dampening, however am considering the OME remote canister units next time.
