Results 1 to 8 of 8
Thread: Oily Pipes and something else... Help identifying a part please
    Beginner denk82's Avatar
    Nov 2017
    SE QLD
    I'm a self-taught backyard mechanic at best. Did my drivetrain service yesterday and when inspecting underneath prior to cleaning up the engine bay I noticed a couple of oily patches. Searched re: oily intercooler pipes as being not uncommon but something else is leaking... Any idea what that small pipe/cable is?
    Pics under driver side. Added pic of the oily pipe as well
    Thanks guys
    Sent from my Pixel XL using Tapatalk
    Assuming its a 3Ltr... These motors are heavy breathers. If the intercooler is original, I'd dare say its leaking. Best thing to do is replace the intercooler and fit a catcg can to can the oily vapours from the motor before they re enter the intake.
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Just been through something similar, a leak in the intercooler will show as a black mist (or worse) on the actual intercooler. This looks like a leak from the hose to pipe connection. Pretty easy to remove the intercooler and hoses to check.
    If no holes clean it up also clean the hoses and refit, make sure to use continuous pressure house clamps.
    If it’s stuffed get an aftermarket ting welded Intercooler and after market hoses, cheaper and better than the original.
    Also if you do fit a catch can, make sure you get a genuine Provent 200 DON’T get a cheap copy.
    Jack
    2024 Isuzu MUX
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Maybe intercooler as suggested above. I have also had a leaky rocker cover gasket cause oil to run along the side of the motor and come out quite a distance from the actual leak.
  5. #5
    Quote Originally Posted by 4bye4 View Post
    Yep! And this too. Leaking injector seals also....
  6. #6
    Nov 2017
    SE QLD
    I'll look at the intercooler this weekend cheers guys
  7. #7
    With that amount of oil the intercooler will have to be leaking quite bad. As mentioned, check the rocker cover and injector seals.
    Sent from my crapPhone using Tapatalk
  8. #8
    177 Post(s)
    The oily areas in the photos are soaked with oil.
    For the intercooler to leak THAT much, you'd have to have serious boost loss and/or performance loss.
    Personally, I highly doubt the intercooler is the culprit in this case.
  9. The Following User Says Thank You to Hodge For This Useful Post:
    denk82 (29th June 2018)
