CJ all the way from Canberra to Melb to have work done , why is that or are you just going to be down here anyway ?
I connected my ScanGauge and Dash Cam up a couple of days ago , have engine oil temp , auto temp , volts and Ltx100K's showing . I'm not sure about the voltage reading it seems to be all over the place
Engine oil temp and Auto temp seem to be about the same give or take , is that right or have I set it up wrong .
Anyone here use a SC or similar what numbers have you seen ?
Filled the tank for the first time yesterday , got about 15.5 - 16 Ltx100k , worked out manually but the tank was full when I picked it up from the dealer , gauge said full , but not sure if it was Full/full
( you know what I mean ) or what they actually put in it 91-95-98
I filled with 98 yesterday.
