Results 1 to 4 of 4
Thread: Belts
    Expert Hardyards's Avatar
    Townsville
    Belts
    Hi gurus
    I have just brought new belts (alt,aircon and pwr steer) using the numbers I got from an old thread ( thanks Cuppa) but now I’ve inspected the old ones, I’ve found them to be solid ( internal surface of belt a flat smooth surface), whereas the new belts are ‘toothed’ so:
    Are toothed( little V’s) belts interchangeable with the single surface ‘solid’ internal surfaced belts? I am changing the belts before heading up the Kimberley’s in a couple of weeks.
    2006 GUIV DX 4.2 TDI Ute, Bullbar with Warn winch, Narva round spotties, scrub bars and side steps, Snorkel, Dual Battery system, Waeco fridge, 2 x Narva spotties an 80W solor panel on roof, Custom tray, 3" Redback exhaust, Bluemax 2 - EGT/Boost Oil press/Temp and dual volt gauges, Lifted, front locked and fully loaded......
    If you can't stand behind our troops, feel free to stand in front of them!
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Toothed or grooved ,if it's a V belt that's the way some make them but if it's a flat with teeth for a V pulley it's not the right belt .
  3. The Following User Says Thank You to GQtdauto For This Useful Post:
    Hardyards (28th May 2018)
    A vee belt of the same size be it toothed or smooth will perform well. The cogged belt config gives the belt greater flexibility and is designed to go around smaller pulleys.
    Townsville
    Cheers guys
    New belts fitted ( after mandatory trip back into town ‘cos one was too long) took 1 1/2 hours but next time would be heaps quicker as I now know the job.
    Thanks for the info.
