Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Caravans sheesh.
    Sep 2011
    adelaide
    18 Post(s)
    G`day 10g.
    I`ve done the lot from swag to caravan, way back in 2001 we decided to forkout for an off road smallish van, did alot of research and were in negations for a new unit to be built to our specks. But while this was happening I was browsing the second hand market and there it was, a unit that I was investigating, only problem was the lay out was not quite what we wanted but as it had only done 350klms and me saving around $9000 over the new price the deal was done. I still have it and since 2001 it has most probably clocked up some 300-350 thousand Ks with well over half on dirt and tracks. since buying it , Yes I have done a couple of mods , removed things that we did not want and added a couple of things we needed. Point being. We bought what we thought would suit our needs then did a few mods, but I knew what I basically,wanted and then did the mods.Personally I would not by a new van, but would look at some thing around late 90`s and early 2000, vans don`t do many k`s ,well not many and there are a lot of older, much better built units that you can do a few mods to out there at very good dollars. My unit is a 2001 Supreme Get Away(pop top) , internal length 4mts external width is 2mts and weights in at 1800 kgs Pluses, Full steel tub, independent suspension, 3ton rated axle and bearings ,12inch brakes, easy set up, most times I don`t disconnect(for one night stop overs) no wet pack ups. Easy hitch up and go as the only thing I load at home is food and beer, every thing else is ready to go. Best of luck with your decision.
  2. The Following User Says Thank You to pearcey For This Useful Post:
    AB (22nd May 2018)
  3. #22
    May 2016
    lower west victoria
    30 Post(s)
    G`day 10g.
    Thanks pearcey. Sounds like you've done what I plan on doing, getting an older van and putting in it what we need & want & ditch the other stuff.
  4. #23
    May 2016
    lower west victoria
    30 Post(s)
    What do I need to put om the Patrol?
    So far I have the factory tow bar and bolt on rear coil support brackets. I guess I need van brakes and mirrors. Anything else?
    Do these 3L CRD Patrols pull vans OK? I probably wouldn't look at anything larger than 16'.
  5. #24
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    You'll need extension mirrors to stay legal (I have them but don't fit them as I have a rear-view camera), also a brake controller and possibly an upgraded trailer plug. My van has ESC so needed a bit of extra wiring. Highly recommend a stone guard to save your rear window.
    As for towing power, you'll know it's behind you when you get around the 2000kg mark, my Eagle was around 1400kg fully loaded and was breeze. With the Eagle I averaged about 16.5 litres per 100 Km on our big trip, the new van has increased that to about 17.5L/100km.
    Don't expect to be passing anything going up hills, but hey you're on a holiday so enjoy the scenery,
    Jack
    2024 Isuzu MUX
  6. The Following User Says Thank You to jack For This Useful Post:
    GQtdauto (22nd May 2018)
  7. #25
    Sep 2011
    adelaide
    18 Post(s)
    Sorry mate don`t know much about the 3lt patrols but towed mine with a n old 93 petrol for the first13 years with no troubles (only fuel but hey it use to get 23lt per 100 either flat out , standing at the lights or towing)Now I tow it with a youbeaut 2.5 Triton MN , with no problems. (35,000 around WA and some 20,000around Tas) so if sensible no reason the patrol wouldn`t tow something around the 14-16ft under 2,000kg van anywhere.
  8. #26
    Patrol Freak gaddy's Avatar
    redlands
    Nothing wrong with doing a old van , all up cost me $ 6000 when finished , put in new suspension and re wired it , took it on the Birdsville trk , Strezz, and cordillo downs, plus dozens of beach runs . Only updated ( well 2003 Supreme Territory ) to get a few more comforts ( shower /toilet )
  9. The Following User Says Thank You to gaddy For This Useful Post:
    AB (22nd May 2018)
  10. #27
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    @10G
    Have a Jayco Pop Top which I am thinking of selling
    $7,000 mark
    If you are at all interested PM me and I will give you further details & Pics
  11. The Following User Says Thank You to Bob For This Useful Post:
    MB (22nd May 2018)
  12. #28
    483 Post(s)
    Parking fees unpaid on the later ‘right’ side pic top van @Bob mate!
    Much better view forward outa your actual windows;-)
  13. #29
    May 2016
    lower west victoria
    30 Post(s)
    Thanks everyone for the great advice and tips.
