Results 1 to 7 of 7
Thread: Help hard to start in morning
    Advanced Apples's Avatar
    Bacchus marsh
    Hi guys I have a 3l patrol. It takes a long time to get it to kick over. You can hear the battery dropping in charge. But when it's fired up it runs great. After the morning start its starts fine. Any help would be great.
    Apples
    .......... TPC's Avatar
    63 Post(s)
    Have you had the battery checked?
    Assuming it is a diesel it could be glow plugs, try turning the key to ignition and when glow plug light goes out turn it to off and to ignition again to get a double glow plug period and see if it starts easier.
  3. The Following User Says Thank You to TPC For This Useful Post:
    Apples (28th September 2016)
    Bacchus marsh
    Yes it's a diesel. I'll try this and see how it goes. I'm not sure about the battery as it came with the car. I'll get it checked too.
    May 2018
    Same issue, have you resolved this?
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Cold weather . Battery fail time
    99% chance it will be one of four things,
    Glow Plugs
    Glow Plugs
    Glow Plugs
    Sad battery not getting the glow plugs up
  8. The Following User Says Thank You to the evil twin For This Useful Post:
    garett (11th May 2018)
    Advanced Dougy's Avatar
    Jan 2013
    If it's not the glow plugs/ battery it may be your pressure control valve on the common rail
    2011 ST, Steel bulbar, warn winch, snorkel, arb rear bar, uhf, dual batteries, on board compressor, 2" OME suspension
