Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: 4.2 tdi coolant temp
    Jan 2018
    CORE SIZE:
    630mm(H) X 570mm(W) X 32m(T) 1 ROW
  2. The Following User Says Thank You to drgtr For This Useful Post:
    dpetersen (9th April 2018)
  3. #22
    Jan 2018
    Adrad one with measurements . Same as above https://www.ebay.com.au/itm/Radiator...MAAOSwuMZZCYUT
  4. The Following User Says Thank You to drgtr For This Useful Post:
  5. #23
    Expert dpetersen's Avatar
    Jan 2015
    Watarrka National Park
    6 Post(s)
    Quote Originally Posted by drgtr View Post
    Thanks @drgtr. Looks like the adrad it the go!
    2006 4.2 tdi wagon
    Plenty more to come!
  6. #24
    Aug 2011
    River Heads Q
    4 Post(s)
    I have aftermarket VDO temp gauge and now have sorted the problem of large movements up and down(60 to 115) because cable from sender was lying on top cable for EGT for some distance to rear of dash and obviously stray current was causing problems.Glad I installed Dessert Cooler radiator before last trip to the West.
    Not impressed with VDO Aust distributor as they do not answer phone or return calls when a message is left.
  7. #25
    Jan 2018
    Quote Originally Posted by dpetersen View Post
    How did you go in the end? All worked out?
  8. #26
    Jan 2015
    6 Post(s)
    Changed the rad with the adrad. It was sitting on around 90* at 100k p/h with temps about 45 outside. If I pushed it any harder to say 110, temps got to around 108*.
    Iv fitted a 3inch exhaust since then though with dump pipe, new injectors and a tune plus a rebuilt fuel pump. Hasn’t really been hot enough since though to test it out though so will have to wait until summer now.
    2006 4.2 tdi wagon
  9. The Following User Says Thank You to dpetersen For This Useful Post:
    drgtr (18th June 2019)
  10. #27
    Jan 2018
    Where do you have the temp sensor again?
  11. #28
    Jan 2018
    Also advance your timing too. It will go sooo much nicer and lower EGT too
  12. The Following User Says Thank You to drgtr For This Useful Post:
    dpetersen (18th June 2019)
