No not at all mate, unplug the Loom to the immobiliser and you will use that wire. Once you get the hole thing off it will expose the other end of the loom, just put a spade plug on it and plug it back in.
There are 3 wires from the loom at the plug, turn the ignition on and only 1 wire will have 12v, that's your wire mate, the other 2 can be blanked off.
I recommend you have handy a little mirror and a torch to check what's going on as its bloody tight in there, but you are basically cutting this thing off balls and all mate.
It is bolted to the pump with security bolts that break off when fitted and simply can't be undone, I did not even try.
The Backing plate was the hardest piece to remove though, I think mainly because I could to tell if it was a backing plate or the bloody pump mate! Once I got under it though it was obviously a plate.
I MIT have some other pics, I certainly have the pieces I removed still, if you need any more just ask away mate.
You mentioned the backing plate.
So if we used long nose pliars to remove the security screw. Will the backing plate just then come out?
