MudRunnerTD
The most important part of getting the right torque on your wheel nuts is to Grease your Wheel Studs. If you have never put lube on the wheel studs then friction will give you torque settings that might not be true and could be significantly looser than expected.
I hand thread to a couple of turns then rattle on then Torque wrench to finish. Grease every time the wheel comes off though.
